Sewer Gas Smell - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-23-2012, 10:32 PM   #1
Sewer Gas Smell
For the last 2 days I have been getting a pungent sewer gas smell from a cabinet in my kitchen. This cabinet is not under the sink, but it is against the wall where I believe the main vent runs.
It has been raining pretty bad for 2 or 3 days as well. I noticed a few things:
1 The smell is present in the cabinets of all bathroom sinks
2. I don't smell anything from the drain openings
3. The smell was almost gone then the wife ran the dishwasher - WREAK!
Am I correct in assuming that there must be a clog in a vent pipe?
All the drains flow quickly. Could there be a clog at the main sewer trap outside the house which could cause the smell?
I have never had this issue in the 5 years we've lived here. The house was built in 1993 so I know all the fixtures have P-traps and no modifications to the plumbing have been made.
My plan is to go to the roof & snake the vents (& run some water in them) to see if it clears this out. Should I open & check the sewer main trap outside, or is that not needed since all the drains flow quickly?
Any guidance would be GREATLY appreciated.
cabreco is offline   Reply With Quote
Old 05-23-2012, 10:55 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Have you been under the house to see if perhaps you have a broken line below?
What kind of traps do you have? Are they S-Traps? (famous for self siphoning)
Journeyman Plumber
Old 05-23-2012, 11:27 PM   #3
My house sits on a slab with no crawlspace.
Yes they are all S-traps
Old 05-24-2012, 12:18 AM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 770
But you said your house was built in '93 and your traps were p traps.
Old 05-24-2012, 05:17 AM   #5
My apologies, due to the hour I was writing this (the problem is weighing heavy on my mind) I mis-typed.
The house uses all P-TRAPS
Old 05-24-2012, 09:12 AM   #6
Doing it myself
Alan's Avatar
Pictures of the traps would be great at this point.
Journeyman Plumber
Old 05-24-2012, 05:02 PM   #7
P-Trap
Old 05-24-2012, 07:37 PM   #8
Doing it myself
Alan's Avatar
Could it be a wind eddy problem with the vents? Do you keep your windows open this time of year?
Are you on a septic tank?
Journeyman Plumber
Old 05-24-2012, 07:50 PM   #9
Nope, city sewer and the cental a/c is running. One thing that was brought to my attention is the huge amount of rain we've had recently, & the fact that my developement was build on what once was a swamp. The fact that I have a sewr easement on my propert doesn't help.
I have been recommended to put down lime for the odor.
Old 05-25-2012, 02:12 PM   #10
Homerepairguy's Avatar
Rewards Points: 998
1. Smell from a cabinet in the kitchen where the main vent runs but not in kitchen sink cabinet.
2 The smell is present in the cabinets of all bathroom sinks
3. I don't smell anything from the drain openings
4. Never had smell in 5 years.
5. All P-traps.
6. Raining pretty bad for last 2-3 days.
7. The smell was almost gone then the wife ran the dishwasher - WREAK!
Are the bathrooms back-to-back? Are the bathrooms clustered close to the kitchen or a room or two away? A floor plan of how your rooms are laid out would be helpful.
Seems that the smell is getting into the double walls and propagating between rooms. Does your home have all ceilings (not open beam)? If so, does the attic smell?
Your picture seems to indicate foam sealing the drain pipe at the wall. Is that correct?
Just trying to gather info that might be helpful to everyone,
HRG
Homerepairguy is offline   Reply With Quote
Old 05-25-2012, 06:12 PM   #11
NO
Two on 2nd floor just above one 10 ft away on the ground floor
See below
The 4 red circles indicate vents on roof
The smell is coming from the corner (blue box)
Yes all ceilings
NO
YES, I had a peek a boo mouse a few years back
HRG
Also the city has have numerous sewer trucks pumping the sewers so it may actually NOT be my house.
Old 05-25-2012, 06:43 PM   #12
Rewards Points: 998
Thanks for posting your nice floor plan. Summarizing again:
5. All P-traps.
8. All pipe openings in bathroom cabinets sealed with foam a few years ago to prevent a mouse from getting into the double walls.
Question: Did running the dishwasher produce the smell only in the kitchen cabinet? Or also in the bathroom cabinets too?
Since all of the openings into the double walls were sealed per step-8, the smell can't be coming from the double walls. Looking at your floor plan and your comments, I can't think of anything. Hopefully, someone will think of a cause.
HRG
sewer gas smell when using washer cgratsch Plumbing 6 01-27-2014 12:09 AM
Back pitch sewer pipes and sewer smell..? HeatherJ Plumbing 15 04-23-2011 11:13 AM
Studor Mystery: Sewer Gas Smell StudorCrazy Plumbing 3 02-20-2010 11:49 AM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 08:37 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
