Sewer Gas Odor From Tub Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-09-2011, 11:51 PM   #1
Rewards Points: 14
Sewer gas odor from tub drain
I have isolated the source of sewer gas to the tub drain in our lower bathroom. I suspect it is a blocked vent pipe. I am not sure what to do next. It is the lower bath in a 3 story house, but still above ground. The vent pipe is not blocked on the roof but I am not sure how to check for blockage lower in the pipe. There is no evidence of leakage around the tub or anywhere else I can see. There are 3 other baths in the house. All the sinks and toilets drain an flush without problems.
I have been in the 32 year old house over a year and the odor started about a month ago. I've removed the overflow and plug and flushed with water, drain cleaner, bleach, and other "miracle" products.
The laundry drain is about 6 feet away but no odor emanates from it or sink or toilet when I seal off the toilet.
Any thought on what to do next short of tearing out the tub.
Thanks in advance.
Cjb4 is offline   Reply With Quote
Old 08-10-2011, 04:14 AM   #2
Rewards Points: 342
Call a plumber who knows how to do a smoke test
plumberinlaw is offline   Reply With Quote
Old 08-10-2011, 11:24 PM   #3
Rewards Points: 14
I guess I will have to. But how do you do a smoke test and what will it reveal?
How to avoid sewer problems or gain the upper hand in a home purchase LateralConcepts How To Guides 0 02-01-2011 11:10 AM
Tap 2" Drain Pipe into 4" PVC Main Sewer Drain Pipe brmatthews Plumbing 3 12-20-2010 07:49 PM
Basement Floor Drain & Sewer Gas 1914 Home Plumbing 4 09-26-2009 03:46 PM
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 07:09 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
