Sewer Gas Coming From All Drains - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-07-2008, 04:04 AM   #1
Sewer gas coming from all drains
I am getting a sewer gas smell from every room in my house with a drain.
It is a basement entry home on a concrete slab. I have read many posts on this site and don't know what I should do.
richez555 is offline   Reply With Quote
Old 05-07-2008, 08:28 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Do the trap gurgle after they drain out? Could be a venting problem.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 05-07-2008, 05:28 PM   #3
Long-Time DIYer
Mike Swearingen's Avatar
I agree with Ron (he's a pro, I'm not). Sounds like a vent problem. When a vent is blocked, any water draining through the system will siphon the water out of the traps (which are there to prevent sewer gas from getting back into the house), creating artificial "vents" and allowing sewer gas in.
Go up on the roof and inspect for blockage in all vent pipes (leaves, trash, birdnest, etc.). Clean out all that you can reach by hand, and flush the vent pipe down with a water hose sprayer.
If that doesn't do it, you may have to snake the vent pipes with a heavy-duty plumber's snake, and then flush them down.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 05-07-2008, 06:15 PM   #4
Send a message via AIM to Marlin
Careful pulling out what you can by hand. Occasionally bees will decide it's a good place for a nest or something else living will have gotten in there.
Marlin is offline   Reply With Quote
Sewer Pump: How to make do? austinbirdman Plumbing 2 05-04-2011 09:35 PM
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 07:09 PM
Sewer pipe under concrete driveway marejw Plumbing 7 12-22-2007 04:19 PM
drains are backing up eleven22 Plumbing 19 12-20-2007 09:21 AM
Sewer Drains Unregistered General DIY Discussions 1 04-24-2004 05:27 AM
