Sewer Ejector Close To Main Stack - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-05-2013, 01:18 PM   #1
Sewer ejector close to main stack
Hi!
New to the forum, but have been searching for answers here for a while.
I'm in the process of remodeling my basement and adding a bathroom. Per town's code I can't tap into main sewer stack in the basement and have to add sewer pit & pump. Which is fine. It'll be 1st time doing something like this, but I like to learn & do everything properly. There is a good chance I'll have a plumber - friend of a friend - come and hook everything up once I get all the prep work done, or at least make sure I get it done right. But I don't have a luxury of bothering him with all the questions, and I certainly can't afford to pay him for the whole job.
I've done some research already, and have basic layout planned out. Where I want to put a sewer pit is very close to main sewer stack. How close to the main stack can I put this pit? I heard that usually there is good amount of concrete right around the main pipe. That would be helpful to know before I start breaking the floor. Also, is there a risk of damaging the main pipe while I'm breaking the floor close to it? And by close I mean about 1 foot away.
What would be the safe distance?
Also, while we're at it - do you think this is ok unit?
LINK
I understand that determining factor would be how much water would flow through, but I'm not sure how to calculate that. I will have a toilet, shower & sink, plus possibly will be draining laundry in there too. No one will be living in the basement; it'll be just big entertainment room for me and my friends + little work out corner. Only 2 people living in the whole house right now.
vladens is offline   Reply With Quote
Old 04-05-2013, 06:13 PM   #2
Rewards Points: 1,766
The Grinder sump should connect into 4 inch pipe. The DFU is based on GPM rate of the pump. Most pumps will exceed what 3 inch pipe is allowed to carry. It is not based on the fixtures the pump serves.
The pump you show has a 90 GPM flow rate and that is 180 DFU You need to go to 4 inch. Do not forget the vent on that sump. You cannot use an AAV valve as a vent.
Old 04-07-2013, 11:56 AM   #3
Hi!
Thanks for the reply. But could you please explain that in more simple language please?! What is DFU? And what's your verdict on the pump/basin in the link? Is it ok?
Old 04-15-2013, 10:30 AM   #4
Also another question - is a clean-out required with this kind of setup? The fixtures probably will be 5-6 feet from the basin.
Old 04-15-2013, 10:52 AM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 432
Originally Posted by vladens View Post
Hi!
DFU = Drainage Fixture Unit. Every plumbing fixture has a DFU rating- or discharge capacity.
For the UPC code- 7.5 GPM= 1 DFU
Pipes are sized by how many DFU's they will carry.
Code states your chosen pump is to be sized at 2 DFU's per 1 gpm
I'm not familiar with your pump brand
UPC states runs less then 5'- cleanouts may be omitted but cleanouts are a good thing to have
Check valve for main sewer mazzonetv Plumbing 12 11-04-2012 08:23 AM
Tub and shower directly to main stack? weekendwarrior9 Plumbing 2 10-10-2012 12:52 AM
Tie stack to main drain rtoni Plumbing 3 04-21-2011 07:49 AM
Main stack issue Elka Plumbing 3 10-14-2009 11:17 PM
Main Sewer Line repair Unregistered Plumbing 3 03-14-2005 08:10 AM
