Sewer Drains - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-08-2012, 01:20 PM   #1
sewer drains
what heads available for roto rooter cable?
clements is offline   Reply With Quote
Old 06-08-2012, 01:25 PM   #2
rotorooter cable heads
I have a qualified plumber who has tried 3 major cable heads with no drain clearing results. Is there a special tool that corkscrews and automatically expands to the inner diameter of the drain line - probably a 3 inch line.
thanks
Old 06-08-2012, 01:40 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 566
What's casing the blockage? I usually use knives unless it's grease. Then you need to jet it.
Sent from my iPhone using DIY Forum
The Following User Says Thank You to TheEplumber For This Useful Post:
clements (06-08-2012)
Old 06-08-2012, 01:45 PM   #4
Question
Originally Posted by clements View Post
i have a qualified plumber who has tried 3 major cable heads with no drain clearing results. Is there a special tool that corkscrews and automatically expands to the inner diameter of the drain line - probably a 3 inch line.
i need help
Old 06-08-2012, 01:55 PM   #5
Plumber
Rewards Points: 566
i need help
Perhaps a longer cable?
Old 06-08-2012, 02:36 PM   #6
joed's Avatar
Rewards Points: 12,448
A camera will show you what the problem is. If the pipe is collapsed you can count on digging it up and replacing it.
Old 06-08-2012, 04:50 PM   #7
Thats the way Im leaning here. When in doubt film it out.
Op
there also a locator that can be sent down the pipe with a beeper that will actually tell you 'WHERE" the pipe is relation to ground and depth.
Comes in handy when we hoe out trenches
21boat is offline   Reply With Quote
Sump drains to sewer butchbs1985 Plumbing 8 09-06-2011 11:14 AM
no methane gas or sewer smell of any sort coming out of any drains or vents kurt2 Plumbing 9 03-04-2011 09:43 AM
How to avoid sewer problems or gain the upper hand in a home purchase LateralConcepts How To Guides 0 02-01-2011 11:10 AM
Sewer smell from under sink and adjoining closet, but not from drains? aaronb9 Plumbing 37 09-27-2009 06:42 PM
Sewer Drains Unregistered General DIY Discussions 1 04-24-2004 05:27 AM
