Old 10-02-2011, 02:29 PM   #1
Sewer Drain Leak?
I just replace 6' or so of a 6" ceramic sewer pipe. It does not appear to be leaking however but there is dampness under the rubber adapter I have installed. Are these usually water tight? How can I fix this?
Thanks Tom
Painterabroad is offline   Reply With Quote
Old 10-02-2011, 02:32 PM   #2
AlbacoreShuffle's Avatar
Sewer Drain Leak?
YES They should be water tight.
Take them off and make sure the pipe is clean and free off debris sticking to it.
Then re-install the coupler.
AlbacoreShuffle is offline   Reply With Quote
Old 10-02-2011, 05:56 PM   #3
Sewer Drain Leak?
Thanks, better now than latter. I must be missing so debris.
Tags
sewer drain leak?
No Caulk Shower Drain - Leak 9lostboy5 Plumbing 12 03-26-2010 11:00 AM
Basement Floor Drain & Sewer Gas 1914 Home Plumbing 4 09-26-2009 04:46 PM
Washer on/off drain leak opper3 Plumbing 1 03-02-2009 06:06 AM
Leak from a PVC Drain Pipe firemedic589 Plumbing 3 01-27-2009 03:44 PM
Leak at flange and drain pipe tallycat77 Plumbing 1 07-26-2005 09:32 PM
