Old 12-19-2012, 08:46 AM   #1
Sewer Cleanout Replacement
The sewer cleanout adjacent to my parking bay was run over and the cap is now broken. For whatever reason the contractors installed a 6" diameter cleanout for a residential townhouse. I want to replace the cleanout cap with one that is traffic rated. I assume I can use a rotor tool to cut off the top, broken area (cutting it from the inside) and then just set the new cap onto the vertical PVC pipe extending to the ground level...? Secondly, does anyone know where I can find a 6" diameter, traffic rated cleanout cap? Thanks!
SER56 is offline   Reply With Quote
Old 12-20-2012, 06:04 AM   #2
"Nail-Bender"
You probably should have posted this in the plumbing forum - with a picture.
However, you can find a 6 inch clean-out cap at a plumbing supply house.
rossfingal
rossfingal is offline   Reply With Quote
Old 12-20-2012, 08:19 AM   #3
Master Plumber
Javiles's Avatar
go in to your local plumbing supply not H/D tell them what you have and what you want to do, clean out should be recessed with a second deary cover to absorb the weight, this cover may just pop off or with screws usually steel or cement, there are various types. its like a water meter box but for this application.
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
TheEplumber (12-20-2012)
Dirt in sewer cleanout fatanddumb Plumbing 7 09-20-2011 12:52 AM
Sewer cleanout - which side of trap? KE2KB Plumbing 4 08-29-2011 09:56 AM
How to avoid sewer problems or gain the upper hand in a home purchase LateralConcepts How To Guides 0 02-01-2011 12:10 PM
Cannot locate outside sewer cleanout dkl Plumbing 9 05-28-2010 09:35 PM
Can I attach a toilet to sewer cleanout? MnMan Plumbing 4 07-30-2008 09:14 PM
