Sewer Cleanout Extension? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-20-2011, 09:23 AM   #1
Rewards Points: 14
Question
I have a tricky situation that I haven't been able to gain clarity on so I figured I would poll the collective minds of this forum for some support.
I have a Sewer Clean-out in my basement that is recessed about 3" below the cement slab (inside of a 5" diameter hole). I am finishing this space and putting in laminate flooring over a plywood subfloor, but I obviously need to retain access to the clean-out.
What I am looking to do is find an adaptor that has a male threaded end that can extend the clean-out up to flush with the flooring and then finish it off with a flat brass cap. To do this, I assume the fitting/coupling would need to have a threaded female end opposite the threaded male end that goes into the existing clean-out. I cant seem to find such an animal.. and I going about this the wrong way?
Thanks in advance for your support!
Dave H
davehazle is offline   Reply With Quote
Old 08-20-2011, 10:07 AM   #2
They make adapters to glue joints. You may need to just need to solvent weld 2 adapters together.
GottaFixIt is offline   Reply With Quote
Old 08-20-2011, 04:00 PM   #3
Rewards Points: 14
Any way you could include a pic of what you are referring to?
Old 08-20-2011, 04:24 PM   #4
a male adapter to screw into the existing c/o and a fitting/spigot female adapter for your brass cap should work. cant tell you how high it will bring you but that will raise it.
male adapter
http://www.lowes.com/pd_23324-1814-P...3D2&facetInfo=
cleanout adapter
http://www.lowes.com/ProductDisplay?...llow&cId=PDIO1
these are 3 inch but they make them in 4 inch also. you might have to go to a plumbing supply
How to avoid sewer problems or gain the upper hand in a home purchase LateralConcepts How To Guides 0 02-01-2011 11:10 AM
Extension for cleanout acerunner Plumbing 8 10-23-2010 07:56 PM
Small Manhole Cover for sewer cleanout nbige Plumbing 5 06-22-2010 09:06 AM
Cannot locate outside sewer cleanout dkl Plumbing 9 05-28-2010 08:35 PM
Can I attach a toilet to sewer cleanout? MnMan Plumbing 4 07-30-2008 08:14 PM
