Sewer Cleanout.. - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-28-2013, 09:11 PM   #1
Sewer cleanout..
We have an old castiron main drain leaving the house and want to install a proper cleanout about 2' from the house. Last time it needed to be snaked/declogged the plumber just dug up the pipe outside close to the house knocked a 2" hole on top of the pipe, ran the snake to clear the clog somewhere out in the yard then caped the hole with a slit rubber sleve with clamps. I was wanting to put a cleanout in this location with cap, is there a specific T fitting that will go cast iron to PVC or should I just cut out a 1' or so section of the drain, insert a angled PVC T with screw on cap and use the rubber sleves on each end to connect back with the iron pipe?
Exjay is offline   Reply With Quote
Old 04-28-2013, 09:42 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 990
You'll need a 2way clean out tee, 2 no hub adapters, 2 no hub couplings a threaded female adapter and plug. piece of pipe a saws all with a diamond blade or a chain cutter, or a grinder to cut the pipe. not a difficult task, this is the correct way of installing a clean out.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 04-28-2013, 09:48 PM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 990
this is what it should look like sorry pictures not coming up,
Old 04-29-2013, 01:06 AM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 444
Something like this-
Old 04-29-2013, 09:03 AM   #5
Yes, thanks Mr. E! Got a close-up of the no hub adapters by chance? Im just familliar with the rubber sleave type. thanks.
Old 04-29-2013, 10:15 AM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Journeyman Plumber
Old 04-29-2013, 06:28 PM   #7
Gotcha thanks again.
Old 04-29-2013, 10:03 PM   #8
Master Plumber
Javiles's Avatar
Rewards Points: 990
no hub adapter ----------------------No hub couplings
Sewer Cleanout Replacement SER56 Plumbing 2 12-20-2012 08:19 AM
Dirt in sewer cleanout fatanddumb Plumbing 7 09-20-2011 12:52 AM
Sewer cleanout - which side of trap? Ultrarunner2017 Plumbing 4 08-29-2011 09:56 AM
How to avoid sewer problems or gain the upper hand in a home purchase LateralConcepts How To Guides 0 02-01-2011 12:10 PM
Can I attach a toilet to sewer cleanout? MnMan Plumbing 4 07-30-2008 09:14 PM
