-   -   Sewer cleanout.. (http://www.diychatroom.com/f7/sewer-cleanout-178315/)
Exjay 04-28-2013 08:11 PM
Sewer cleanout..
We have an old castiron main drain leaving the house and want to install a proper cleanout about 2' from the house. Last time it needed to be snaked/declogged the plumber just dug up the pipe outside close to the house knocked a 2" hole on top of the pipe, ran the snake to clear the clog somewhere out in the yard then caped the hole with a slit rubber sleve with clamps. I was wanting to put a cleanout in this location with cap, is there a specific T fitting that will go cast iron to PVC or should I just cut out a 1' or so section of the drain, insert a angled PVC T with screw on cap and use the rubber sleves on each end to connect back with the iron pipe?
Javiles 04-28-2013 08:42 PM
You'll need a 2way clean out tee, 2 no hub adapters, 2 no hub couplings a threaded female adapter and plug. piece of pipe a saws all with a diamond blade or a chain cutter, or a grinder to cut the pipe. not a difficult task, this is the correct way of installing a clean out.
Javiles 04-28-2013 08:48 PM
this is what it should look like sorry pictures not coming up,
TheEplumber 04-29-2013 12:06 AM
199 Attachment(s)
Something like this-
Exjay 04-29-2013 08:03 AM
Yes, thanks Mr. E! Got a close-up of the no hub adapters by chance? Im just familliar with the rubber sleave type. thanks.
Alan 04-29-2013 09:15 AM
http://common2.csnimages.com/lf/47/h...b-Coupling.jpg
Exjay 04-29-2013 05:28 PM
Gotcha thanks again.
Javiles 04-29-2013 09:03 PM
2 Attachment(s)
no hub adapter ----------------------No hub couplings
