Sewer Clean Out Cap - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-31-2013, 04:12 PM   #1
Sewer clean out cap
I was looking at my sewer clean out and trying to figure out how to remove the cap. It is not a threaded cap and appears to be a slide on. It looks like this http://cammackranchsupply.com/store/...?productid=273 How can I remove this
gsensel is offline   Reply With Quote
The Following User Says Thank You to gsensel For This Useful Post:
grizzzlle (02-01-2013)
Old 01-31-2013, 04:50 PM   #2
Rewards Points: 13,732
That's a cap and should not have been used as a clean out access.
Sure it's not glued in place?
Got a picture?
Old 01-31-2013, 05:20 PM   #3
I haven't tried to remove it yet. Wasn't sure how to go about trying to remove it another site the person said to try tapping lightly and see if it will move. Can I add that has the threaded lid? (after the current is removed or cut.)
Old 01-31-2013, 09:37 PM   #4
r0ckstarr's Avatar
Rewards Points: 2,052
Please post a picture of your actual cap in place.
r0ckstarr is offline   Reply With Quote
Old 01-31-2013, 09:43 PM   #5
Here is a picture of my actual clean out.
Old 01-31-2013, 10:11 PM   #6
Rewards Points: 258
you sure that is a clean out???????? seems like its too small
redman88 is offline   Reply With Quote
Old 01-31-2013, 10:16 PM   #7
looks like they forgot to come back and cut it down after the grading was done and put a clean out on it.
Old 01-31-2013, 10:36 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 682
That would be my guess too.
Take a hammer and tap upward on the lip of the cap - tap alternate sides- see if it comes of. Often times the cap is just pushed on the pipe and not glued. Replace it with a female adapter and plug
Old 02-01-2013, 06:15 AM   #9
r0ckstarr's Avatar
If you don't want to take a chance of damaging anything, put a small board up against the lip of the cap and use the hammer to hit the board. May make it easier to do as well.
Old 02-01-2013, 07:56 AM   #10
http://www.bing.com/images/search?q=...electedIndex=0
Old 02-01-2013, 09:06 AM   #11
747
registered
747's Avatar
Rewards Points: 534
Originally Posted by joecaption View Post
This is what i have.
Looks like they just capped it. Hopefully its not glued.
747 is offline   Reply With Quote
Old 02-01-2013, 12:40 PM   #12
Well I went out to look and see about getting the cap off and as soon as I applied a little force that whole PVC part lifted out. Which I guess means the whole thing was a cap or at least not secured with anything.
Should I just put it back in or is there a way I can put a correct style clean out in? Or would that be better done by a plumber?
Old 02-01-2013, 12:42 PM   #13
Plumber
Rewards Points: 682
Are you saying the riser came out of the ground or the cap came off
Old 02-01-2013, 12:44 PM   #14
The riser came out
Old 02-01-2013, 12:48 PM   #15
Plumber
Rewards Points: 682
Sounds like gasket sewer pipe pipe. Try to get the riser back in as best you can- the dig up the 45 at its base. Post a picture at that time and we'll get you squared away- no need to call a plumber.
Clogged Sewer Line adowling Plumbing 19 06-28-2011 06:37 PM
how to clean payne gas sensor? dapperdraker Appliances 3 06-26-2011 12:28 PM
Clean oil off of tools, also clean the inside of a compressor capslock Tools 1 12-23-2009 11:36 AM
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 07:09 PM
sewer backup and stench jayhill Plumbing 12 08-13-2008 11:06 PM
