Sewer Backed Up In Basement Floor Drain And Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-09-2009, 10:17 AM   #1
Question
sewer backed up in basement floor drain and shower
I consider this my warning... a small amount of sewerage backed up into my floor drain and shower.
Are there any products I can use to clean out the main sewer line?
I know there are backflow devices available. What are the costs to have these installed??
Is there anything else I should look at?
thanks, Kristina
kristina1961 is offline   Reply With Quote
Old 04-09-2009, 06:14 PM   #2
Rewards Points: 150
call a plumber to snake out your sewer. Then have him run a camera in there to see what is going on. More than likely you have a partial stoppage in your building sewer line. Usually this is caused by tree roots but there are alson other reasons too. a camera will answer most of your questions. I would not suggest you renting a sewer machine and doing it yourself as if you are not sure what you are doing you could get seriously hurt.
al's sewer is offline   Reply With Quote
Old 04-09-2009, 06:17 PM   #3
Rewards Points: 150
thanks, Kristina
I am not a big fan of back flow devices on sewer lines as most of the ones I have seen cause more problems than they solve. but that is just my opinion.
Old 04-09-2009, 06:27 PM   #4
that's what I thought...
I appreciate your quick response! We don't know the history of the house so one never knows the problems that might arise.
There is a big tree in the backyard, close to the house... I thought the tree roots might be the culpret.
I love this forum. What a great way to get opinions about home improvement!
Old 04-10-2009, 07:14 AM   #5
Man
You are the man with straight answers, I really respect you.
SULTINI is offline   Reply With Quote
Old 04-10-2009, 07:37 AM   #6
one thing to consider, you said the tree is in the back yard, do you have city sewer or a septic system, makes a difference on what could be causing your problem, good luck.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 04-10-2009, 07:47 AM   #7
we have city sewer... what are your thoughts?
Old 04-10-2009, 08:14 AM   #8
I was thinking with city sewer, most likely your sewer pipe exists the house in the front, a tree in the back yard could but most likely not be the problem. I would stick with Al's idea to have some one come out and snake the line. You could do that yourself but unless you've done it before or have someone with you who has, you could get hurt.
LIVING THE DREAM
Old 04-12-2009, 06:58 AM   #9
Rewards Points: 150
I love it when people agree with me
Old 04-12-2009, 07:34 AM   #10
Man of many hats
wrangler's Avatar
Rewards Points: 354
If you do call out a plumber, ask him if there is a cleanout installed, and if not, to install one while he is there. It is possible that this might happen again, and having a handy cleanout will aid in the future. I say this, because I have had to snake mine twice for the same problem. The cause in my case is due to the contractor that built this neighborhood. For what ever reason (money, I'm sure) he had the sewer from my house and the neighbor's house come together and 'Y' into the city sewer line. This causes a blockage about every two years.
Man of many hats
wrangler is offline   Reply With Quote
Old 04-12-2009, 09:07 AM   #11
Rewards Points: 150
It is illegal here to have 2 houses on one sewer line. Everytime we run into one we are obligated to call the city and let them know. Needless to say we get cussed out quite a bit because the ho's have to pay to resolve the problem and the city will not take no for an answer. naby friendly neighbors were not so friendly after that
Old 04-13-2009, 12:19 AM   #12
Listen to Al. he knows poop.
plumber Jim is offline   Reply With Quote
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 11:54 AM
Basement bathroom shower drain conversion coyotewaits Plumbing 1 01-08-2009 01:17 AM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
shower in basement slab philip96 Plumbing 2 06-15-2008 09:46 PM
Basement shower drain help.. helpless handyman Plumbing 79 02-26-2008 09:39 PM
