Sewer Back Up / Replace Wax Ring? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-01-2012, 09:20 AM   #1
sewer back up / replace wax ring?
Our main sewer line stopped up, I was taking a shower and noticed it was draining slow, when I got out I noticed a bit of water had even leaked out around the base of a toilet we recently had replaced......not a lot of water but enough I had to get a towel to get the water up. Anyway I called a plumber and he unstopped the main line......now my question -
should I pull the new toilet and replace the wax ring? it is less than a month old and hadn't leaked before or since we had the main drain issue?
thanks in advance
gcan is offline   Reply With Quote
Old 04-01-2012, 09:45 AM   #2
Rewards Points: 636
yes use new wax ring might use new toilet bolt also to line up when setting since bolts are usually cut shorter after install
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 04-06-2012, 08:43 AM   #3
You should change your toilet and also check the condition of your septic tank whether it is full or not.
bobsmith00 is offline   Reply With Quote
Old 04-06-2012, 07:36 PM   #4
thanks for the reply Bob, I didn't mention the previous owner had the tank pumped just before we purchased the cabin, it's a weekender, and I also recently replaced the toilet.
I said he unstopped the line but actually the stoppage ended up being the PVC line pulled apart just past the foundation where it 45's to the tank. Between the 45 and the angle of the fall it appears the tank settled a bit and the pipe pulled out of the fitting. They repaired the line just wasn't sure about the wax ring since the toilet was just recently installed.
Old 04-06-2012, 09:48 PM   #5
Rewards Points: 1,574
"You should change your toilet...
Why change the toilet?
bob22 is offline   Reply With Quote
Old 04-07-2012, 03:14 PM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Why would you change the toilet???????????????
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 04-07-2012, 03:15 PM   #7
plummen's Avatar
Try snugging the bolts on toilet before removing it
Old 04-07-2012, 07:08 PM   #8
I didn't think to try and tighten the bolts.....since it was just recently installed it may have seated and this may work.....it's the simple things we forget
Old 04-07-2012, 08:53 PM   #9
Rewards Points: 6,652
During the reno of our bathroom, I knew that I would be pulling the toilet multiple times, so I ended up going with a Waxless ring. After the six or so removals, it has not leaked at all. It is a lot easier to make a leak tight fitting, than messing with a wax ring.
The Following User Says Thank You to gregzoll For This Useful Post:
plummen (04-08-2012)
Which is better? WAX or Non-Wax toilet ring? KUIPORNG Plumbing 16 08-28-2016 12:52 AM
Sump to sewer, sewer gases bergerdude Plumbing 5 12-01-2011 07:14 PM
Removing compression ring? ruzz Plumbing 30 10-01-2011 07:14 PM
Sewer Pump: How to make do? austinbirdman Plumbing 2 05-04-2011 10:35 PM
Need help making a 'back band' around window/door casing. RickDel Carpentry 3 07-15-2010 04:13 PM
