SEWER BACK UP, Which Flood Control Good????? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-08-2008, 08:16 AM   #1
we have a tri level house with a sub basement.
at least once a year, with heavy rain or long rain, the city sewer backs up causing our lower level family's toilet & standing shower to back up.
we've contacted a couple of companies a flood control, but not sure which would more helpful?
1st system called parks double guard flood control:
http://www.parksplumbingandsewer.com...trol/index.htm
this system uses case iron valve
2nd system: flood control by xpert flood control
http://www.floodexperts.com/backup-valve/
anyone have experience or opinion ? thanks much.
diyjt5259 is offline   Reply With Quote
Old 10-08-2008, 10:44 AM   #2
DIY'r
ScottR's Avatar
INSTALL BOTH! EEEEWW..
Seriously though, I've (thank everything) had no experience with this situation, but with the first solution I'm thinking there could be an issue with your local codes about putting pressurized waste directly into the sewer main. On the other hand, if the company sells/installs it in your area, it's probably kosher. (And if the muni sewer was backing up into my basement regularly, I'd be more concerned with my basement than the muni's code).
A backflow prevention device (as in both systems) definitely seems like a goooood idea.
ScottR is offline   Reply With Quote
Sewer Pump: How to make do? austinbirdman Plumbing 2 05-04-2011 09:35 PM
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 07:09 PM
sewer line back fall oakie14 Plumbing 2 09-04-2008 05:36 PM
Sewer pipe under concrete driveway marejw Plumbing 7 12-22-2007 04:19 PM
