Sewage Under House: How To Remove Smell - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-25-2007, 02:45 PM   #1
Hi, the main sewage drain under my house developed a leak and although now fixed I am left with the smell of sewage that I would like to neutralize safely. I spread an household antibacterial solution (Lysol) to take care of the bacteria and it is reasonably dry, although a little damp down there. My plumber recommended I spread Lime under the house. Are there any powder products I can spread down under the house crawl space to neutralize the odor without harming the occupants? Calcium Oxide but I read a bulletin from NJ saying this is harmful for the lungs.
Many thanks for a speedy response.
rajivsab is offline   Reply With Quote
Old 11-25-2007, 02:46 PM   #2
Hydrated Lime Seems to be the best answer but which one to use???
Lowe's has a 50 lb bag, Type "S" Hydrated Lime made by Chemstar used for mixing in Concrete I believe. The link is:
http://www.lowes.com/lowes/lkn?actio...98-286-1118-60
And then there's the "Garden Lime" variety 5lb bag which is less toxic I believe.
Here's that link:
http://www.espoma.com/content.aspx?t...egoryID=2&id=8
Which one to use for my purpose? I believe the Chemstar one will need a mask and careful precaution. I do have 2 ground heaters sitting in the crawl space and that stuff may come into the house so maybe the garden variety will be safer for the occupants. What do you think?
many thanks.
Old 11-25-2007, 11:55 PM   #3
That one Guy's Avatar
Lime is good but harmful. I get mine from the fruit packing places around here. One of our guys burned a hole in his arm with that stuff when it was mixed with water. I hear it can make a body vanish in 48 hrs if buried in it. No im not a serial killer lol. You can use any organic drain cleaner similar to what Roto-Rooter has. It will neutralize the bacteria and kill the smell.
That one Guy is offline   Reply With Quote
Old 11-26-2007, 09:57 AM   #4
Rewards Points: 884
Bacteria isn't a bad thing, it's a good thing, especially concerning sewage. As bad as it smells, the odor of sewage is the bacteria digesting the waste and turning it into harmless by-products, and water. You should have left the sewage alone, instead of killing the microbes that were working for you.
The WORST thing you can pour down your drains are household cleaners, especially Lysol and bleach, both of which destroy bacteria and microbes and can render a septic/ cesspool system useless.
LawnGuyLandSparky is online now   Reply With Quote
Old 11-27-2007, 07:53 PM   #5
Bacteria in septic tank= good
Bacteria under the house= not cool
Old 11-27-2007, 08:31 PM   #6
Send a message via AIM to Marlin
Lots of bleach.
Marlin is offline   Reply With Quote
Sewage Under House: How To Remove Smell?? rajivsab General DIY Discussions 1 11-25-2007 02:42 PM
Smell outside my house scalcen General DIY Discussions 8 11-23-2007 04:10 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 06:42 PM
Old House sewer smell. Need Help! crytal Plumbing 7 11-30-2006 05:30 PM
'Earthy' smell in house from crawl... HilleMary Building & Construction 5 08-30-2005 10:13 PM
