Old 10-09-2009, 02:40 AM   #1
Question
Sewage smell from pressure relief valve drain
when ever we use large amounts of water, we seem to be getting some kind of sewage odor (not like rotten eggs) from the hot water tank pressure relief valve drain.... is this drain trapped? should it be filled with water?
daveh20 is offline   Reply With Quote
Old 10-09-2009, 10:48 AM   #2
If you mean the floor drain then yes it should be trapped and holding water. If the trap is dry add some water.
plumber Jim is offline   Reply With Quote
Old 10-09-2009, 11:45 AM   #3
Yes. Any drain that ties into your house drainage system should have a trap and it should have water in it. This is a common problem with floor drains that don't get much usage. The water evaporates and allows sewer gas to enter the home.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
More On This Topic
Hi! This is John on behalf of Expert Village. In this video clip, I will show you step 9 of our process for installing a ball valve. The next thing that we want to do is go ahead and open up our ball valve so that water will flow through our pipes. Again... Read More »
Hi! This is John on behalf of Expert Village. In this video clip, I will be showing you step 6 of installing a ball valve. I am going to go ahead and show you a few tips for soldering. I am going to solder this ball valve on the ground primarily for the... Read More »
Hi! This is John on behalf of Expert Village. In this video clip, I will be showing you step 7 of installing a ball valve. All right I am going to go ahead and put some solder paste on the end of my pipes, and this is going to help that solder flow a... Read More »
Hi! This is John on behalf of Expert Village. In this video clip, I will be showing your step 8 for installing a ball valve. When finished, you should have a ball valve shown similar to the one here. I went ahead and replaced that handle after I was done... Read More »
Hi! This is John on behalf of Expert Village. In this video clip, I will show you step 1 for installing a ball valve. I am going to be installing a ball valve on this pipe. This pipe is a hot water pipe, and I know that because when I trace it back, it... Read More »
Low hot water pressure crebive Plumbing 26 01-10-2010 12:54 PM
Sewage smell after repair- HELP mimijim1 Plumbing 3 01-18-2008 05:15 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Pressure Balancing Valve Installation kpstanton Plumbing 2 03-01-2007 11:30 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
