Sewage Smell From Internal Waste Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-17-2010, 05:56 AM   #1
Sewage smell from internal waste pipe
We have a smell of sewege coming from what we think is the internal waste pipe in our kitchen.
We have checked the sink, bath etc drains and put unblocking stuff down there. Toilet isnt blocked. Had the waterboard out to check the manholes in the garden all clear. Cleared the outside drains and again all clear. checked the top of the pipe near the roof and its clear.
We cant see much of the waste pipe as its tiled around in the bathroom and boxed in and kitchen units over in the kitchen area. The only part we can see is the very bottom under the kitchen unit where we have pulled the washing machine out.
We think the pipe is cast iron and there is a small amount of damp on the concrete floor but not wet and no visible leaking.
Any ideas, this is driving us crazy.
jellybean11 is offline   Reply With Quote
Old 03-17-2010, 07:19 AM   #2
Assuming all the traps have water in them, you could have a broken pipe. A trap that has dired out or been siphoned out will alllow sewer gas into the house.
Old 03-17-2010, 08:40 AM   #3
Rewards Points: 1,418
A rat happened to choose that location to get stuck in and die and decay?
Use every sink and basin and shower and tub just a little each evening to make sure the traps are full. Also pour some water downt he washing machine drain, where the hose is suposed to fit loosely. If there is a trap that is leaking itself dry you will then be able to see wetness on the floor somewhere.
Can you see every trap? (Toilet drain pipes do not have traps; the toilet itself is the trap.)
You're sure that the smell is not coming from a drain opening such as in a sink?
Old 03-17-2010, 10:10 PM   #4
Rewards Points: 150
Dry Trap
The previous posts are headed you in the proper direction. I don't know your level of expertise with plumbing so forgive me if I am too basic. The trap in the waste line, that kind of "S" bend in the visible portion under the sink, should hold water all of the time, this prevents the sewer gases from entering the building. Traps will siphon themselves dry when they are not properly vented. If you have an old house and have an "S" trap, one that goes down through the floor and then drains into a waste line, the trap is not vented properly and so is probably siphoning itself dry. Traps installed today are "P" traps, these traps tie into the waste line horizontally and is likely to be properly vented. Assuming that the odor is a recent development I would check to see if the vent is clogged. If you are in a cold climate and have an old undersized vent pipe through the roof it may be that the vent is actually closing up with moisture from the waste lines freezing and clogging the vent with ice.
TheCamper is offline   Reply With Quote
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 01:03 PM
Old Galvanized Waste pipe rodg2915 Plumbing 1 02-28-2007 03:39 PM
Waste pipe odor in garage? Kirsten Plumbing 3 11-21-2006 01:07 PM
Leaking waste pipe guvlin444 Plumbing 5 09-30-2006 02:36 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
