Sewage Smell After Repair- HELP - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-18-2008, 08:30 AM   #1
Sewage smell after repair- HELP
We recently had our sewer line repaired about 3 feet from the house because there was a separation in the pvc. The house is only 4 years old but digging along the foundation to redo the water proofing we beleive caused the break. The problem started 3 months ago when the smell came and went but the toilets and drain lines all flowed. Apparently some waste made it through the line and some went through the break. We have a basement and the sewer is a hung line that feeds into a pod which pumps into the main line. It's been a couple of days but we can't find any relief from the smell and had to move out . I have ran chlorox and water in the two sump pumps in the basement and opened windows but this hasn't helped.
Any suggestions?
mimijim1 is offline   Reply With Quote
Old 01-18-2008, 10:22 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Is the septic or city sewer?
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 01-18-2008, 01:39 PM   #3
Rewards Points: 1,514
Any cracks or a loose lid or connections at the pod (holding tank)?
Any water stains in the concrete or mortar where the sewer pipe exits the house?
Does the water in one toilet bowl jiggle when another toilet is flushed? This may indicate a clogged vent pipe (up to the roof) which in turn can cause odors to permeate the house.
Get some dye used to trace sewer leaks. Allow a few days and perhaps several insertions for the test as opposed to just putting a little in a toilet and waiting a few minutes. See if dye shows up anywhere in the basement including in the sump pump pits.
Old 01-18-2008, 04:15 PM   #4
The pod, which has been checked, pumps to the city sewer line. The break that was repaired was next to the house. I know sewage was seeping into the ground for some time. I am not quite sure how to get rid of the smell in the house which seems to be still coming up from the sump pump.
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 01:51 PM
Gas Furnace - Burning smell at return blakemcginnis HVAC 4 01-26-2008 08:29 AM
Sewage Under House: How To Remove Smell rajivsab Plumbing 5 11-27-2007 07:31 PM
Sewage Under House: How To Remove Smell?? rajivsab General DIY Discussions 1 11-25-2007 01:42 PM
