Sewage Smell - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-26-2010, 10:31 AM   #1
Sewage smell
We have a strong sewage smell coming from the shower drain in the basement. The washing machine drains into this shower drain. The sewage smell only occurs at night. When we pour some bleach into the drain, the smell goes away, but it returns the next night.
jimh is offline   Reply With Quote
Old 02-26-2010, 09:48 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
If you don't run the washer for a day, do you still have the same problem?
Journeyman Plumber
Old 02-27-2010, 02:48 AM   #3
Rewards Points: 150
Sounds to me you need a vent for the wash machine.
rudolph58 is offline   Reply With Quote
Old 02-28-2010, 02:45 PM   #4
If we don't run the washing machine, we don't get the smell that night. Could the vent be plugged?
Old 02-28-2010, 09:16 PM   #5
Doing it myself
Alan's Avatar
Could be a lack of vent for the floor drain, clothes washer or distance from a vent to the floor drain too great. Sounds like your washing machine is siphoning out the floor drain. Does it have a trap primer?
You shouldn't have to pour bleach into it. Just plain water and the smell should go away if this theory is correct.
Journeyman Plumber
Old 02-28-2010, 11:05 PM   #6
Why not
slightly run the water. Sounds like your p-trap evaporated allowing the gas to escape
noahweb is offline   Reply With Quote
Old 03-01-2010, 10:04 AM   #7
Doing it myself
Alan's Avatar
Water does not evaporate that quickly.
Journeyman Plumber
Old 03-01-2010, 05:50 PM   #8
Rewards Points: 150
are u saying that the washer actually drains into the shower pan or into the same drain as the shower in the floor?if the vent is clogged that could cause trap siphon.
Tags
sewage smell
Sewage type smell coming from bathroom shower drain majorchamp Plumbing 29 06-25-2012 11:08 AM
Bad Sewage Smell in 300yr Old House Natacha Plumbing 7 03-27-2009 11:37 PM
Sewage smell after repair- HELP mimijim1 Plumbing 3 01-18-2008 05:15 PM
Sewage Under House: How To Remove Smell rajivsab Plumbing 5 11-27-2007 08:31 PM
Sewage Under House: How To Remove Smell?? rajivsab General DIY Discussions 1 11-25-2007 02:42 PM
