Sewage Smell - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-14-2013, 04:30 PM   #1
Sewage Smell
So this past Thurs/fri my area had a rain storm. Since, my main floor powder room has smelt of sewage. Wife said she saw water from the bottom of the toilet.
I tested a few times and didn't see anything but went ahead and replaced the wax seal. When I had the toilet off no smell. Put the toilet back on with new seal and still no change. Sewage smell; and its only one bathroom it's confined to
Anyone have any ideas?
Integrated is offline   Reply With Quote
Old 04-14-2013, 04:38 PM   #2
Rewards Points: 14,312
Town sewer or septic?
Is this bathroom used every day, including the sink?
Did you check for weak spots around toilet while it was out?
Is this a new house to you?
Old 04-14-2013, 04:50 PM   #3
Sewer. Everyday inc the sink. Toilet looks ok. I was thinking of replacing anyway but was planning on waiting awhile still. Been in the house 2 years. Never this problem before .
Old 04-15-2013, 08:46 PM   #4
So someone suggested pouring hot soapy water into the drain for the washing machine and bleach into an empty toilet as flush till its gone. Did this and the problem was resolved for a few hours then came back.
Any help??
Old 04-15-2013, 09:00 PM   #5
Rewards Points: 358
Just a suggestion, did wax ring make good seal? Round side on toilet bottom flat side around flange? Another suggestion, sometimes you may need two or a bigger/thicker wax ring to make a good seal. Check out these two links when you get a chance. Homeowner had a similar problem. It may buy you some time until your ready for a whole new toilet. Wax rings are only a couple bucks. New toilet is couple hundred bucks depending on brand. It still may not solve your problem, some pro's will be here soon to give you some better advice.
link here
extra thick wax ring
jmon is online now   Reply With Quote
Old 04-15-2013, 09:55 PM   #6
Master Plumber
Javiles's Avatar
Rewards Points: 996
Check the water level in the toilet bowl not the tank a toilet with a leak in the trap will let gasses in, next step have a smoke test done on the system you'll know for sure.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 04-16-2013, 12:35 AM   #7
Well, what I pulled off was what looked like a rubber/foam sort of gasket.
This was what i replaced it....
http://www.homedepot.ca/product/wax-...-sleeve/925821
weird thing is, when i had the toilet off i really didn't smell anything. Until hours after the toilet was back on.
What about the water level in the bowl?
Old 04-16-2013, 05:33 AM   #8
DIY staff
Rewards Points: 7,174
Failed AAV? (Air Admittance Valve)
This sort of thing only happens in an improper original installation---Consider getting a smoke test--
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 12:57 PM
sewage smell and and history of backup in floor drains jeffzap Plumbing 14 03-17-2013 11:29 PM
Strange sewage smell only during the night time edge323 Plumbing 11 03-01-2013 10:00 PM
Sewage smell from shower drain, trap has water, vent was snaked and was clear clearasmud Plumbing 1 04-24-2011 06:28 AM
Sewage smell jimh Plumbing 7 03-01-2010 04:50 PM
