Sewage Pump For Home - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-10-2004, 07:22 PM   #1
Guest
Guest
Posts: n/a
Question
Sewage pump for home
Hello,
I'm looking into buying my first home, but the property sits lower than the city sewer system. There is a pit outside that houses a pump to send it to the city sewer system but I was wondering if I'm just asking for trouble if I buy the place? Even if I get the right equipment and have it professionally installed?
Old 02-27-2005, 11:40 PM   #2
whenever you have to rely on a system such as this, you always should set up a back-up power source in case you loose initial power. I would also have to have a back-up pumping system in case of equipment failure, because a fault or breakdown of such a facility could be more than just a little inconvenient
Tomm is offline   Reply With Quote
Old 02-28-2005, 09:54 AM   #3
Contractor
A town to the north of me is littered with these micro lift stations and when they lost power due to the hurricanes it was a major concern.
For me, it would be a deciding factor on a home purchase.
Teetorbilt is offline   Reply With Quote
Sewer Pump: How to make do? austinbirdman Plumbing 2 05-04-2011 10:35 PM
looking to upgrade sump pump coeng Plumbing 14 06-04-2007 04:08 PM
Well pump issue-should I be concerned? Mikedks Plumbing 8 10-08-2006 11:42 PM
stuck in well pump hell crossthreaded Plumbing 2 08-21-2006 05:32 PM
Sewage pump problem Unregistered General DIY Discussions 1 10-03-2004 10:52 PM
