Old 09-09-2011, 01:10 PM   #1
sewage pump high water alarm
Can exessive rain (over 9 inches since monday) cause a high water alarm to come on for my myers mw50 sewage pump? never had any problems before
tessrea is offline   Reply With Quote
Old 09-09-2011, 02:20 PM   #2
Super Moderator
It shouldn't set off the alarm--even if the pit leaks and is picking up ground water----
Better pop off the lid and see what's going on.
That pump should be able to keep up with extra water and not over fill.---Mike----
9 inches is a LOT of water----
oh'mike is online now   Reply With Quote
tessrea (09-09-2011)
Old 09-09-2011, 02:35 PM   #3
The alarm light that is on is a myers level alert. Right the green and red light are both on. What would trigger the alarm light to come on? Should we unplug it and see if it will reset.
Old 09-09-2011, 02:56 PM   #4
call me E
TheEplumber's Avatar
Is the pump running? Your pump floats may be stuck. You need to pull the lid and look inside
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 09-09-2011, 04:08 PM   #5
Civil Engineer
I assume this pump is in a pump chamber that leads to your septic system. If not, please tell us where the pump is.
The alarm comes on when the level in the pump chamber exceeds the preset alarm level, which is typically about 6 inches below the top of the pump chamber. The purpose of the alarm is to warn you that the pump is not working, so you will not continue to flush sewage into a full tank, eventually overflowing the tank onto the ground. My neighbor had the same problem, it was a broken pump, but he unfortunately ignored the alarm until there was sewage all over his front lawn.
As noted, you need to open the manhole to the pump chamber and determine if the pump is functional. If not, get it replaced of course, although it could be the float as previously noted, or even the wiring from the house to the pump. If the pump chamber is cracked, groundwater could be flowing into the pump chamber, although the pump should be able to pump out a limited amount of groundwater, as previously noted.
Old 09-09-2011, 04:20 PM   #6
Super Moderator
I assume you meant the sewage pump in your basement.
Do you have a septic system ? Is it a mound system with a pump?
Thank Daniel for his ability to read . Sorry if I jumped to a wrong conclusion.
If that is the problem I will let others take over--My knowledge in that area is minimal.
Old 09-11-2011, 10:40 AM   #7
thanks for all your responses. The pump is now workingt again. We cleaned the prongs on the plug - lots of buildup on them. I don't know if that took care of it or if our drain field lines finally dried up enough for the pump to have a place to push the water, but we are so glad all is working now. However, this incident did help us learn a whole lot more about this type system and what we need to do to maintain it so we can hopefully keep it going well for a while. Again, thanks to all.
The Following User Says Thank You to tessrea For This Useful Post:
oh'mike (09-11-2011)
Old 09-11-2011, 01:26 PM   #8
RachelRoberts's Avatar
Send a message via Yahoo to RachelRoberts Send a message via Skype™ to RachelRoberts
No idea on a "how long it's been running" option, but the most absurdly strong and reliable bilge alarm I could find (and installed myself a few months ago) is this one from Defender:
http://www.best-pressure-washer-reviews.com/best-pressure-washers.html
RachelRoberts is offline   Reply With Quote
Old 09-11-2011, 02:59 PM   #9
always make sure that if the high water alarm is sounding off, that the pump is running, sometimes it could be that the pump is just not keeping up, also the float could be hung or has gone bad, or a wire connection...periodically check inside to make sure everything looks ok especially if you know they are calling for a lot of rain...
http://www.hawthornesplumbing.com
pdhawthorne is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Pump that will push waster water (unrine) from my urinal to my sewage line Carl2 Plumbing 1 03-27-2011 07:29 AM
Standing water in ductwork due to high water table on the lake HVAC 0 01-03-2011 06:58 PM
Sump Pump Water Level Lucky000 Plumbing 5 10-02-2010 08:05 AM
Water Stinks with recirculation pump carike Plumbing 6 08-05-2008 09:01 AM
