Sewage Pump Float Clearance - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-14-2011, 07:18 AM   #1
Sewage pump float clearance
Hi, we are replacing a sump pump (installed by previous owners) with a sewage pump. The pump itself fits into the existing basin (both are RIDGID), but there is not a lot of clearance. The float may touch the side of the basin occasionally. Our problem is that the big 18x30 basin will not fit in the area closed off for this. Will the pump work in the smaller (existing) basin, and if not, is there any medium-sized basin?
hlynch is offline   Reply With Quote
Tags
basin , clearance , sewage pump
need sewage ejector pump recommendation bandl Plumbing 1 05-11-2011 09:35 AM
Plumbing a sewage ejector pump noviceguy Plumbing 3 03-11-2011 09:59 AM
Sewage grinder pit and pump installation leff1rj Plumbing 15 02-04-2011 11:36 AM
Sump pump float height dac122 Plumbing 8 12-08-2010 08:47 AM
frozen outflow from sewage pump? lukathonic Plumbing 10 12-11-2009 04:55 PM
