Sewage Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-14-2011, 05:58 PM   #1
Rewards Points: 29
Sewage Pump
I want to put a bathroom in basement as I am finishing everything. the sanitary pipe out of house is higher hten the finished floor.. Is it often people use sewage pumps for basement bathrooms?
Shawn
Shawnzy is offline   Reply With Quote
Old 11-14-2011, 06:18 PM   #2
DIY staff
Rewards Points: 7,174
All modern homes in this area have the lateral drains higher than the floor---so sewage pits for the basement are always required-----you will need one for your new work---
Old 11-14-2011, 06:40 PM   #3
Rewards Points: 29
we have a sump pump now can I just change that into a sewage pit
Old 11-14-2011, 06:41 PM   #4
Rewards Points: 29
get a sewage pump and a secure lid?
Old 11-14-2011, 06:44 PM   #5
Rewards Points: 29
how much fall do you need in the pipe for 6 ft vertical to a run 15ft long to the sanitary pipe?
shawn
Old 11-14-2011, 07:14 PM   #6
2inch pipe needs 1/4 inch to the foot, 3 inch can have 1/8 per foot. a sump pit is not a sewage pit. You need one of these:
http://www.plumbingsupply.com/sewage.html
Old 11-16-2011, 07:03 AM   #7
DIY staff
The sump pit is already in use to drain the foundation drain tiles---don't even think of putting sewage into that---
Sewage Pump - Replace? H2O Engr Plumbing 1 07-06-2011 11:42 AM
need sewage ejector pump recommendation bandl Plumbing 1 05-11-2011 09:35 AM
Plumbing a sewage ejector pump noviceguy Plumbing 3 03-11-2011 09:59 AM
Sewage grinder pit and pump installation leff1rj Plumbing 15 02-04-2011 11:36 AM
frozen outflow from sewage pump? lukathonic Plumbing 10 12-11-2009 04:55 PM
