Sewage Pit Collapsing From Water (ground) Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-23-2011, 09:50 PM   #1
sewage pit collapsing from water (ground) pressure
my sewage pump died and I have suspected ground water was leaking into the pit as the pump would trip with no internal activity. Upon removal I noted the plastic basin is collapsed due to ground water pressure and water is seeping in slowly over the basin upper rim. Ideas please
jeffg is offline   Reply With Quote
Old 09-23-2011, 10:03 PM   #2
Missouri Bound's Avatar
Not too sure what your question is, but pretty sure that ground water pressure won't collapse a properly installed basin.
Installing Sprinklers appear to have caused Water Pressure to DRASTICALLY increase geminigirl Plumbing 3 11-12-2009 01:04 PM
Water pressure dropping tucsoncop Plumbing 2 04-25-2009 01:19 PM
New Pressure Switch -- low water pressure chach Plumbing 4 01-18-2009 10:50 PM
Water pressure and temperature billvasko Plumbing 9 06-02-2008 10:23 AM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 11:29 PM
