Sewage Line And Vent Design New Basement Bath - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-27-2012, 10:20 PM   #1
Rewards Points: 14
Sewage line and vent design new basement bath
What would be the best/easiest way to run the sewage lines and vents in this layout (or a similar layout). I have attached a basic layout sketch. The less concrete I have to bust out the better.
Does the toiled need a vent or is it close enough to the main line/vent to be considered vented? Can the shower and tub lines be vented together?
Here are actual photos of my sewage pipes:
https://lh5.googleusercontent.com/-C.../IMG_00401.jpg
https://lh5.googleusercontent.com/-w...G_0041text.jpg
Thanks for any advice.
JayRay is offline   Reply With Quote
Old 01-27-2012, 10:26 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
The toilet looks fine
Run a 2" to the tub, put a 2" Y in for the shower, Bring the 2" up and back to the vent
Run a 1 1/2" to the sink and bring the 1 1/2" up at a min 6" above the sink level and back to a vent
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 01-27-2012, 10:29 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 904
Is the new layout upstairs or in the basement?
Where is the existing stack located on the drawing?
The Following User Says Thank You to TheEplumber For This Useful Post:
plummen (01-28-2012)
Old 01-27-2012, 10:34 PM   #4
Rewards Points: 14
I guess I didn't need to post the upstairs bath pictures, that caused some confusion. The main stack is on the left of my drawing, in blue. The new layout is of the basement. Thanks.
Old 01-27-2012, 10:44 PM   #5
Rewards Points: 560
The problem you may have is that the distance from the building drain to the tub and will you have the difference in elevation you will need to get proper slope for the 2" pipe
Old 01-27-2012, 10:51 PM   #6
Master Plumber
Javiles's Avatar
Rewards Points: 996
Also depends what code you’re under. Under our code you would need two vents in that system. Maybe one depending on the distance between fixtures.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 01-28-2012, 12:30 AM   #7
Rewards Points: 14
I am fairly certain I can get the required slope in the 2" tub pipe. Where does the vent have to come off the main tub line? Thanks for the replies.
Old 01-28-2012, 09:25 AM   #8
Rewards Points: 560
Bring the vent to the end of the run for both the sink and tub
Old 02-04-2012, 04:17 PM   #9
Rewards Points: 14
The line from the tub to the main sewage line is 9 feet, I don't think I can wait to vent it at the end of the run can I (unless I run 3 inch lines)? For further clarification the large vertical red line is the main vent, the smaller vertical red line on the right is a vent that was added later by someone else for a small basement bathroom that was subsequently torn out. The horizontal red line is the main sewage line going outside the house, the clean out is right below the main vent stack. The main sewage line running out of the house in the basement is pretty deep, that is why I think I can get the required slope in my tub line. I'm rethinking my layout now however, anything to make all that concrete removal easier.
Cheers.
Valid vent for basement bath? bdowden Plumbing 4 09-30-2011 03:43 PM
Help with basement bathroom vent satchfan Plumbing 3 12-26-2010 09:35 PM
Finishing a basement bath Vent? Pump-up toilet connection heenanp Plumbing 0 03-23-2010 06:43 PM
Can a roof vent identify where my main sewer line exits the house? YerDugliness Plumbing 8 01-26-2010 04:13 PM
finishing a basement bath - tie in to ejector pump vent? ajbowman Plumbing 7 04-15-2008 12:09 AM
