Sewage Lid + Check Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-07-2008, 09:22 AM   #1
Sewage Lid + check valve
I am not sure what the official terminology is, but I talked to my local city waste water and they came out to check the sewage lines because of another problem I am having. The main sewage line out to the street is clear, so he said the next step is to open the sewage lid (that rusted brown/grey lid next to the house). I don't know if its called a sewage lid, but I will use that term for the time being.
He said there are 2 pipes/valves in this hole. One of them is a check valve I guess and he said to check that for any blockages, hair, etc... He said its like a little flip lid that should be clear of any obstructions.
Could someone point me to an image / diagram of what I should be looking for? I have never opened one of those before.
So:
1. Help me clear up my terminology
2. Point me to an image/diagram that can assist me diagnosing this problem.
majorchamp is offline   Reply With Quote
Old 07-07-2008, 09:45 AM   #2
I should add, the lid is metal and probably about 10 inches in diameter. Someone pointed me to a septic lid cover, but a google image search shows those lids to be much larger then what I have.
I use city services and live in a suburban neighborhood.
Old 07-07-2008, 10:06 AM   #3
Ok, so what it is called is a Sewer Clean out. In it is the check valve once I take the top off the white PVC pipe.
So at that stage is where any additional information on cleaning it out is appreciated.
Jackel Eco Systems DJ-545 check valve pesphoto Plumbing 5 05-20-2008 08:49 PM
sump pump issue mikehende Plumbing 15 02-15-2008 06:36 AM
Question about sump pumps and check valves lennyseleven Plumbing 3 11-08-2007 10:33 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
