Sewage Evacuation Pump Replacement? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-25-2013, 08:54 AM   #1
Question
sewage evacuation pump replacement?
How do you replace the pump? Problems to look for? Steps in the process?
loliverre is offline   Reply With Quote
Old 04-25-2013, 05:23 PM   #2
Rewards Points: 2,108
Replace it as you would a normal sump pump. Make sure you keep all the seals on your sump lid in good shape. If there is a ball valve on the discharge shut it off first. Unplug the pump second. Otherwise you may get a feces shower...
Use the correct pump not a water sump. Use a grinder sump.
Old 04-25-2013, 06:34 PM   #3
Owner
LateralConcepts's Avatar
First of all, how do you know it needs to be replaced? Have you checked for blockages? Checked the float switches? Checked circuit breakers? GFI's?
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Sewage ejector pump in basement johnd2 Plumbing 8 12-07-2013 10:48 PM
holes in sewage pump basin? marketbridge Plumbing 2 09-05-2012 02:38 PM
proper size sewage pump bergerdude Plumbing 3 08-15-2012 12:42 PM
Replace buried sewer line or install sewage pump? greendog Plumbing 0 04-07-2012 06:32 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
