-   -   sewage evacuation pump replacement? (http://www.diychatroom.com/f7/sewage-evacuation-pump-replacement-178065/)
loliverre 04-25-2013 09:54 AM
:(How do you replace the pump? Problems to look for? Steps in the process?
Ghostmaker 04-25-2013 06:23 PM
Replace it as you would a normal sump pump. Make sure you keep all the seals on your sump lid in good shape. If there is a ball valve on the discharge shut it off first. Unplug the pump second. Otherwise you may get a feces shower...
Use the correct pump not a water sump. Use a grinder sump.
LateralConcepts 04-25-2013 07:34 PM
First of all, how do you know it needs to be replaced? Have you checked for blockages? Checked the float switches? Checked circuit breakers? GFI's?
