Sewage Ejector Tank Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-27-2011, 10:07 AM   #1
Unhappy
sewage ejector tank replacement
I have a sewage ejector tank in the basement with a line coming from a bathroom. After needing to replace the float switch, I noticed the sides of the tank appeared to be bulging in. Also, during rain, the pump activates without any activity from the bathroom. I assume there is ground water leaking into the tank. Should the tank be replaced and are there any other alternatives?
dave zirkle is offline   Reply With Quote
Old 04-27-2011, 10:33 AM   #2
DIY staff
Rewards Points: 7,174
Post a picture if you can-----sealing the pipes to the tub might be all you need to do---
However if the tub is a thin one and it's collapsing--replacement with a tougher tub might be the only sane option.--Mike---
Old 04-27-2011, 10:38 AM   #3
Looks thin
Thanks Oh Mike, The walls do look thin. Just wondering how big of an undertaking the replacement would be?
Changing Size of Replacement Window joside Remodeling 10 05-30-2012 04:46 PM
Plumbing a sewage ejector pump noviceguy Plumbing 3 03-11-2011 09:59 AM
window sash replacement kits? jimhome Remodeling 5 11-02-2009 12:48 PM
Sewage Lid + check valve majorchamp Plumbing 2 07-07-2008 10:06 AM
sewage building code for home owners aokss Plumbing 9 09-11-2006 06:37 PM
