Sewage Ejector Pump In Basement - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-29-2012, 10:29 AM   #1
Sewage ejector pump in basement
Sewage ejector pump was installed in finished basement bathroom. Sewer smell emanates in house at different times. Not always. On occasion (infrequent) when pump goes, a little water backs up though the washing machine line.
The ejector pump has a vent, looks to be vented to the side of the house. A sink and shower drain to the ejector, the washing machine does not. The drains work fine, when I run the sink, the water in the shower trap does move slightly up and down. I am trying to find out if this is a venting issue...and advice how to eliminate sewer smell would be greatly appreciated
johnd2 is offline   Reply With Quote
Old 11-29-2012, 09:00 PM   #2
If "...a little water [effluent] backs up though the washing machine line" when the ejector discharges, there may be some sort of blockage in the main building drain out to the sewer, or septic tank. If you do have a septic tank, when's the last time it was pumped out?
Ishmael is offline   Reply With Quote
Old 11-29-2012, 09:13 PM   #3
Rewards Points: 582
check vent from ejector....also if sewage is backing up into washing machine line ...thats not normal...should be checked out could be the source of the smell..ben sr
Old 11-29-2012, 10:59 PM   #4
Thank you...some water...sometimes backs up through the washing machine drain line...seems like it from the pressure from the pump....not sewer water.....the ejecteor pit looks to be vented to the side of the house....the vent line does take 3 90 degree turns.... one a few feet from the pump than right angle towards the wall..then right angle up the wall and right angle out the house (I think it connected outside the house I can see entire internal syste, system)....
Old 11-30-2012, 09:38 AM   #5
Yes the ejector pit is vented to side of house:
here are a few pictures
Sewage ejector pump in basement-img-20121130-00705.jpg   Sewage ejector pump in basement-hempstead-20121130-00718.jpg   Sewage ejector pump in basement-img-20121130-00708.jpg   Sewage ejector pump in basement-hempstead-20121130-00730.jpg   Sewage ejector pump in basement-img-20121130-00704.jpg
Old 11-30-2012, 09:40 AM   #6
few more pix
Sewage ejector pump in basement-img-20121130-00707.jpg   Sewage ejector pump in basement-hempstead-20121130-00718.jpg   Sewage ejector pump in basement-img-20121130-00702.jpg
Old 11-30-2012, 08:42 PM   #7
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I agree that the water bubbling out of your washing machine standpipe may be the cause of the smell. Please post a picture of the ejector discharge tie in with relationship to the tie in from the laundry's gravity drain.
Journeyman Plumber
Old 12-07-2013, 10:29 PM   #8
The washing machine ties into the cast iron main drain stack. It looks to be not in great shape. The cast iron vent was corroded. I caulked up good, helped.
The washing machine till backs up only on occasion when sewage pump ejects. Should I try a check valve?
patio22 is offline   Reply With Quote
Old 12-07-2013, 10:48 PM   #9
In addition, the ejector pump ties into the same line as the washing machine. The washing machine empties into main stack does not go into ejector. But when ejector pumps, pressure pushes water back through washing machine line.
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Basement wasls, vapor barrier , options for what i have to work with bf514921 Building & Construction 3 07-12-2012 11:26 PM
Advice on finishing my basement? jakec202 Remodeling 1 07-06-2012 03:11 PM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 06:50 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
