Setting A Tub - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-16-2010, 06:14 AM   #1
Setting a tub
I need to set a tub, well mine is a 200lb cast iron shower receptor, but I assume the installation is the same. The manufacturer (Kohler) simply says to move the receptor into position and shim as necessary to make it level.
There are four rather small feet under the receptor, I'm a little worried with all the weight of the receptor and occupant that the feet will push into the plywood floor a bit. Would it be ok to put a metal plate under every foot and then start shimming?
Second, when type of shims do you use? I have an abundance of metal electrical box cover plates (4"X4"), any reason why I can't use those?
Lockeset is offline   Reply With Quote
Old 11-16-2010, 06:21 AM   #2
DIY staff
Rewards Points: 7,174
Those covers will make dandy shims---If you find them to be to thick,check out the roofing tins at the local store---
galvanized ,sold in packs of 10--handy and thin enough for most situations.--Mike--
oh'mike is online now   Reply With Quote
Old 11-16-2010, 08:38 PM   #3
Thanks Mike. I ended up putting a plate under each foot to start, this way I won't have to worry about the foot pushing into the plywood over time. The feet on the Kohler are only 1/4" inch wide so I feel safer now.
I had to add 4 plates to one of the front legs and 1 plate to the other front leg, it came out nice.
The Following User Says Thank You to Lockeset For This Useful Post:
oh'mike (11-17-2010)
Manifold pressure setting on new furnace kb3ca HVAC 21 11-16-2010 05:00 PM
Freezer not cold enough at "normal" setting... skipjack Appliances 2 02-01-2010 03:10 PM
Mud Setting vs. Wonder Board PattiAnn Plumbing 9 12-24-2009 07:55 PM
Least expensive Programmable Thermostat for home with automatic vacation setting Studly HVAC 2 12-15-2009 07:18 AM
How to deal with setting drywall compound? KUIPORNG Remodeling 11 01-11-2007 08:22 AM
