Old 02-08-2007, 01:01 PM   #1
Question
setting a tub
A question and hopefully somebody can answer ... my building contractor is replacing my tub due to a crack that formed in the fiberglass (I believe due to improper setting). So when I expressed my concern about how the new tub will be set they indicated that they were going to use a spray foam to set the tub in ... this seems odd. How can that foam withstand and stay firm when water fills the tub ... it seems that over time foam will compress.
Any comments or thoughts?
Last edited by rosiw; 02-08-2007 at 01:19 PM. Reason: stating the question in the title
rosiw is offline   Reply With Quote
Old 02-08-2007, 01:46 PM   #2
setting a tub
Depending on the size usually use a bed of mortar.
redline is offline   Reply With Quote
Old 02-08-2007, 02:06 PM   #3
setting a tub
Your thinking is correct. The foam will compress over time. I have yet to see a tub manufacturer recommend, or even suggest, using spray foam. Most I have seen suggest or require a mortarbed. For a tub, a 5 gallon bucket of premixed mortar would probably be cheaper and better than the foam.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 02-08-2007, 03:00 PM   #4
setting a tub
thanks for your help ;-)
Old 02-10-2007, 10:17 PM   #5
remodeling pro
setting a tub
We always support the tub along any wall by nailing a ledger to the studs under the flange of the tub, and also as suggested, setting the tub in a bed of mortar. If it is a wood subfloor, put down a layer of felt paper under the mortar. Nix the foam idea, because the type of foam that will be firm enough to offer any support, will also be high expansive and most likely lift the tub when it expands to cure.
troubleseeker is offline   Reply With Quote
premix joint compound vs setting type ITE Drywall & Plaster 23 03-17-2012 12:18 PM
Setting Pilings For Boat House donwells Building & Construction 3 06-22-2009 12:19 PM
Setting Fence Post cibula11 Building & Construction 2 06-22-2007 10:05 AM
How to deal with setting drywall compound? KUIPORNG Remodeling 11 01-11-2007 09:22 AM
HELP! Question About Lousy Tile Setting Job... EricW Flooring 10 09-13-2006 08:02 PM
