Old 01-14-2009, 05:25 PM   #1
Default Setting a Toilet tank against a tiled wall
I'm replacing a toilet in my bathroom and apparently I mismeasured for the new toilet. So now I can get the first part of the toilet down okay, but the tank isn't setting properly because of a lack of clearance between the toilet and the wall. The maddening thing is that it's off by maybe a quarter of an inch.
Is there any way to correct for this? I've tried rocking the toilet forward some, but I'm pretty sure I've reached the limit of the drain hook up. I'm leaning towards buying a new toilet, but I'm to ideas before I take that step.
Thanks!
Julio
jibanez is offline   Reply With Quote
Old 01-15-2009, 08:52 AM   #2
Man of many hats
wrangler's Avatar
It does sound like you might need a 10" backset toilet versus a 12". This will give you plenty of clearance. If you are only a 1/4" shy though, you should be able to get your current commode to work.
Man of many hats
wrangler is offline   Reply With Quote
Old 01-15-2009, 12:23 PM   #3
If you have pulled the bowl as far as it will go forward, and the tank is still on an angle, it will leak when installed or possibly break if you try to tighten it up enough to stop the leak. Measure from the wall to the center of the flange. If you have a 12" rough toilet and the measurement is 11-1/2" or less, you will probably need to purchase a 10" toilet. They do make offset flanges to add up to 2" of distance to the floor flange, but they usually are installed inside the drain pipe which decreases the pipe diameter. This may be another option for you.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 01-17-2009, 09:54 AM   #4
Thanks for the replies! I went ahead with the 10" backseat just to get that bathroom up and running again. So far so good.
Thanks again!
Julio
More On This Topic
We've all heard the frantic request from the bathroom to bring the toilet plunger before the toilet runs over. All of us will cope with a toilet malfunction at one time or another. Some repairs are best left to the experts, but many fixes are simple once... Read More »
Now, to check to see if this toilet has a leak in it, what you can do is you can take, and put a little bit of food coloring into the tank. If there is a leak in this toilet, the water food coloring will go through the tank, and end up in the bowl. So... Read More »
How to Install a Toilet
How to Install a Toilet by Expert Village
Ok, now I'm going to take the toilet, I've got it all in one piece already because its a used toilet and we're going to set it in place. Ok, now I'm a little bit up off the floor because my toilet is just now beginning to squish that wax ring down into... Read More »
Re-installing a Toilet
Re-installing a Toilet by Expert Village
The important thing to re-installing a toilet over its location is you put the toilet; let's say it's over the pipe right now. We try to rock the toilet. If the toilet rocks, we need to pre-shim it. We're going to put shims down ahead of time, so when we... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I will be taking you through our reassembly process. I purchase this complete repair kit from the hardware store now this includes all of the basic workings for replacing the guts of your... Read More »
Low hot water pressure crebive Plumbing 24 11-07-2009 09:55 PM
Sound dampening advice needed steel1 General Discussion 10 10-22-2008 03:51 AM
Hot Water Toilet GeauxCajuns82 Plumbing 1 10-10-2008 11:21 PM
Tips on setting a toilet Yeti Plumbing 5 10-25-2007 05:15 PM
Caulking to a tiled wall drhowarddrfine General Discussion 6 10-04-2006 05:26 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
