Setting A Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-29-2010, 09:18 AM   #1
Rewards Points: 768
Setting a Toilet
After tiling our flange sits about 3/4" below the finished surface. Last time we replaced the toilet we used 2 wax rings. This time I figured on using a flange extender. Is there one method better than the other?
Right now it appears that the wax ring is barely touching the flange....so I definitely need to compensate for another 1/4"-1/2".
cibula11 is offline   Reply With Quote
Old 03-29-2010, 09:26 AM   #2
Military Mom of 4
Snav's Avatar
Flange extenders (or closet rings) are made for this purpose. They're plastic and durable and will NOT have to be replaced if ever in the future you remove your toilet. . . .you attach it through the existing holes in your flange to the floor with a few screws and never have to worry about it again.
This will, also, ensure a proper fit between your toilet and the pipe - you definitely don't want to smell defeat on this one :D
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 03-29-2010, 09:31 AM   #3
Rewards Points: 768
Can I use 2 of them if needed. I already have a larger wax ring, so I'm hoping with the extender I'll be good, but I'm not sure.
I'm assuming that I use silicone between the current flange and the extender?
Old 03-29-2010, 09:42 AM   #4
Military Mom of 4
Snav's Avatar
Yes, you caulk to give the extender a water and gas-tight seal. (sorry, I failed to mention that) if it's not a self-sealing flange. Self-sealing flanges save some time since you don't have to caulk them, but my store never carries them.
Flanges comes in several thicknesses: 1/4", 1/2" and 3/4" - so one should be all you need if it's the right height.
However, my supply store only carries then in 1/4" thickness for some annoying reason - in that case - you would need two or three. They can be stacked like this without problems - just be certain to caulk each layer.
Old 03-29-2010, 09:46 AM   #5
Rewards Points: 768
Thanks,
Home Depot only carries the 1/4" extenders. I'll try some other places first. One might be enough.
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 08:38 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Leaky toilet drain secutanudu Plumbing 0 08-17-2009 11:14 AM
Setting a Toilet tank against a tiled wall jibanez Plumbing 3 01-17-2009 08:54 AM
Tips on setting a toilet Yeti Plumbing 5 10-25-2007 04:15 PM
