Setting A New Tub! Drain Alignment Problems - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-18-2012, 04:17 PM   #1
Setting a new tub! Drain alignment problems
Im remodeling a bathroom and am setting my new bootzcast tub. The rough in trap connection is about an inch too far from the wall for the drain/overflow setup to connect. Is there a flexible trap union for this type of situation? The tub is taking the place of an old fiberglass drop in tub shower.
Any help is greatly appreciated
Chris
crza1 is offline   Reply With Quote
Old 02-18-2012, 04:32 PM   #2
One clarification, this is a tub set on a slab so access to moving the rough in will be a chore.
Old 02-18-2012, 04:40 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 566
If the trap is set too far back, use two 45's or 22's in the vertical overflow section to make an offset to line up with the trap. Also lengthen the drain shoe accordingly. This will require a "solvent weld" type of waste and overflow- not the brass or tubular plastic type.
Old 02-18-2012, 04:49 PM   #4
The tub drain vertical section is farther back than the trap connection.
Old 02-18-2012, 05:57 PM   #5
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Picture?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-18-2012, 06:17 PM   #6
Rewards Points: 528
This is the reason I hire a plumber for this chore....
Sounds like you will be breaking out some concrete to reset the rough plumbing....
framer52 is offline   Reply With Quote
Old 02-19-2012, 05:44 PM   #7
I ended unmaking the trap work by using a fernc rubber fitting to make the overflow alignment better. I also cut away a bit of the insulation on the back of the tub to give more clearance for the nut on the overflow tube. A flexible tub drain would have been a better answer but I don't have local access to one.
The Following 2 Users Say Thank You to crza1 For This Useful Post:
ben's plumbing (02-19-2012), oh'mike (02-19-2012)
Old 02-19-2012, 07:05 PM   #8
Rewards Points: 582
chris maybe I missed it... there is no trap door..if not can you put one in???
Scupper drain installation advice needed miamicuse Roofing/Siding 9 02-11-2012 09:59 AM
drain hose for new dishwasher -doesn't match old one? denemante Plumbing 1 11-01-2011 12:57 PM
Water and drain hookup problems with washer and septic system. Snav Appliances 4 01-27-2010 11:01 AM
Water heater drain pan - can I drain into the washer drain? cjartguy Plumbing 7 04-15-2009 02:34 PM
washing machine drain vent problems rebelbull Plumbing 7 03-29-2009 09:18 AM
