Set Shower Base In Mud - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-06-2013, 06:49 PM   #1
Rewards Points: 111
Set shower base in mud
Hello,
I am going to be installing a pre-formed shower base in a bathroom remodel, I am removing a tub, and placing in a shower. The base I am using is here: http://www.homedepot.com/p/Delta-60-...2#.UbEeIdh27-4
I was going to set the base in a layer of structolite to help level it, and give it full support throughout. My question is with regards to the structolite and bottom of the shower base. The underside of the base has a foam board bottom, covering the whole base. One of the reviews of the product on the HD site says "Great rigid foam base makes it easy to set and is firm with no bounce."
1. If I place the base directly in the structolite, will the structolite degrade the foam board in anyway (basically its like a stiff Styrofoam)?
2. Could I place a plastic sheet between the structolite and bottom of base, so this would not even be an issue?
3. Do I also need a plastic sheet between the wood sub-floor and the structolite, to keep the wood from soaking up water from the structolite?
Thanks in advance,
Steve
svaic00 is offline   Reply With Quote
Old 06-06-2013, 07:14 PM   #2
DIY staff
Rewards Points: 7,174
You will need to call the maker to see if the foam can tolerate the mortar.
Isolating it from the foam with plastic may be all that is required--
If that is a flat bottomed foam pan--you will need very little mortar ---you might wish to use a 3/8 " tile trowel to get an even bed---
TheEplumber (06-06-2013)
Old 06-06-2013, 07:27 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 904
I'm not a fan of showers or tubs with foam on the bottom, but that's just me I guess
I hear complaints of movement and squeeking.
Not sure what structolite is either, but it has been suggested here before to set the foam base on construction adhesive and glue it to the floor. This may or may not work for you- depends on how out of level you are.
Fix For ELM Shower Base Drain Leaks MarkSilber Plumbing 0 02-14-2012 09:02 AM
Stud wall return on a preformed shower base latelifebiker General DIY Discussions 5 11-30-2011 03:56 PM
Plastic shower base and concrete / leveling issue JoTeeBee Kitchen & Bath Remodeling 2 06-17-2011 07:46 PM
Is this ok shower base? acerunner Plumbing 15 04-16-2011 04:48 PM
How to build base for a shower stall atm Plumbing 13 05-13-2009 10:18 AM
