Set Screw Frozen Solid In Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-19-2013, 09:02 PM   #1
Set screw frozen solid in shower
I have two showers with the same exact setup which is a delta monitor single lever shower. The one shower is dripping from the up above shower head so I believe I need to replace the valve insert or whatever it is called. The problem is that the handle set screw is flat out welded on from all the scaling and buildup. I sprayed WD40, CLR to try to unfreeze it without any luck. The second shower is never used so I tested in there and i was able to turn the set screw with 1/8 hex. How can I remove the set screw? Drill it out? What size drill bit? I assume I would need a new lever after this?
grand_canyon is offline   Reply With Quote
Old 03-18-2013, 07:30 PM   #2
Well I've been trying to drill this out without any joy. Do I need a special drill bit. The one I'm using doesn't seen to be budging the set screw.
Old 03-18-2013, 08:15 PM   #3
Roofmaster
Rewards Points: 2,172
Cobalt? Drills turning clockwise right?
Old 03-18-2013, 08:21 PM   #4
The bit is turning clockwise. I didn't use a cobalt bit as I just used a bit that is rated for metal, wood, pvc. Do I need a cobalt bit? If so what size?
Old 03-18-2013, 08:53 PM   #5
Roofmaster
I cant see the set screw, but I would guess 3/16. Drill it out so you can re-tap the handle to take a 1/4-20 Allen set screw. That would be a No. 7 bit if memory serves. You can buy an Irwin matched drill and tap at HD or Lowes. Some of the other guys might know what size that Allen set screw is for sure though. Make sure you use a Stainless Steel set screw and put anti seize compound on the threads this time around.
Good luck to you.
Old 03-18-2013, 08:56 PM   #6
Thanks for the info. The Allen head was 1/8 size. I'm actually needing to replace the cartridge because it drips. I think I will just replace the whole unit and the shower head as well if I can get the dang handle off
Old 03-18-2013, 09:10 PM   #7
Roofmaster
Try just drilling and re-tapping first. You may be getting in deeper than you really want, replacing the whole fixture. Maybe you had a cheap bit. Cobalt really cuts, you'll see.
Basement bathroom shower remodel NewHomeDIYGuy Kitchen & Bath Remodeling 39 11-26-2013 11:20 AM
Tiled Shower Repair Help, Please Unicornz0 Plumbing 2 09-16-2012 10:22 PM
Delta Monitor single handle for shower no set screw. How do I remove it barbjalanj Plumbing 5 07-03-2012 05:17 AM
stripped shower screw betsylwhs General DIY Discussions 2 12-28-2009 09:33 PM
