Set Screw - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-10-2008, 07:02 PM   #1
break-it-yourselfer
Set screw
I am trying to remove the single handle on my shower faucet. It is loose and someone reccomended tightening the handle, or, if that doesn't work, remove the handle and wrap a little teflon tape on the stem and reset the handle.
My problem is that the set screw won't budge in either direction.
I tried some wd-40 but no luck.
Any ideas?
I am afraid of applying too much pressure to the allen wrench and making things worse.
The handle has wobbled for a while (years) should I leave it alsone?
Thanks.
DDASH is offline   Reply With Quote
Old 03-10-2008, 07:34 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
What is the brand on the shower faucet?
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-10-2008, 07:59 PM   #3
break-it-yourselfer
Ron -
I have no idea.
I can't find a brand on it anywhere.
Old 03-10-2008, 08:21 PM   #4
Journeyman Plumber
Post a picture.
Old 03-10-2008, 10:23 PM   #5
break-it-yourselfer
I beleive the faucet is a Price Pfister.
Thats on the overflow plate.
The faucet is a single handle with allen hex set screw.
Old 03-11-2008, 10:04 AM   #6
Journeyman Plumber
If you can't get the set screw out, then you need to break or cut that handle off, then replace everything the stem to the handle, you won't have much of a choice if the set screw is froze
Old 03-11-2008, 05:27 PM   #7
break-it-yourselfer
Any idea what to use on the screw other than WD-40?
Old 03-11-2008, 08:31 PM   #8
Journeyman Plumber
Nope, only what you have tried.
Old 03-11-2008, 08:57 PM   #9
break-it-yourselfer
Thanks-
You probably saved me hours of time and possibly a lot of damage.
I think i'll leave it alone for now and have the plumber look at it the next time he is here.
1950s house - plumber is here at least once a year.
Old 03-11-2008, 11:37 PM   #10
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Not sure if it will work or not, but try a penetrating oil like PB Blaster or Liquid Wrench. WD-40 is a water displacement agent, not a penetrating oil.
JDC is offline   Reply With Quote
Do screw heads really need to be mudded with three coats? KUIPORNG Remodeling 33 09-17-2011 02:54 AM
Sheared head on Tapcon screw - how to remove? mkuether Remodeling 9 12-04-2008 09:18 PM
Remove a screw gpowell52 General DIY Discussions 3 03-03-2008 04:57 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
Ground screw in 4" box fw2007 Electrical 8 10-05-2007 04:07 PM
