Set Back - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-12-2008, 06:43 PM   #1
Set Back
Just a chance someone might have this info in memory bank. How far back from backer board plus tile should a block for attaching the valve of a one handle shower (Delta 17230) be nailed?
rolls831 is offline   Reply With Quote
Old 07-12-2008, 07:34 PM   #2
Send a message via AIM to Marlin
Do you have the direction? Or the rough in plate that comes with the valve? If not you can probably find the directions pretty easially. It's going to depend on how thick your backer board and tile is going to be.
Marlin is offline   Reply With Quote
Old 07-13-2008, 12:01 AM   #3
Licensed Master Plumber
mstplumber's Avatar
Rewards Points: 150
Delta valve installation
Is there a prize?
I'm not familiar with a 17240, but all of Delta's new tub/shower sets use the same rough in valve, a R10000. The face of the blocking/stringer for the R10000 valve needs to be 2 3/4" from the finished wall. So figure out the total thickness of everything that's going on the studs and do the math and you should be good. If you don't get it perfect, don't worry, there is a little room for adjustment on the trim.
Mstplumber
Check out my goofy video for my new toilet repair book.
mstplumber is offline   Reply With Quote
Old 07-13-2008, 01:18 PM   #4
Rolls831
Thanks for the info. I'll grab a piece of backerboard and tile and measure accordingly, should be very close.
Ground rod or not? brotherman Electrical 30 07-15-2008 05:58 PM
replacing metal back borch porch with shingles nurse47557 Roofing/Siding 1 05-22-2008 12:10 AM
sagging kitchen off back of house DanBress Building & Construction 12 03-03-2008 10:20 PM
Water rolling back and hitting nails Malcolm Roofing/Siding 6 08-01-2007 10:44 PM
