Old 01-29-2008, 05:06 PM   #1
Service size pipe 3/4 or 1 inch?
For a one bedroom guest house that will be on a separate meter, is 3/4 supply line adequate from street meter or do I have to run 1 inch.
kgphoto is offline   Reply With Quote
Old 01-29-2008, 05:35 PM   #2
Union HVAC Tech.
If your talking water piping I would go with 1" polybutylene, it's very inexpensive and in case you want to add hose bibbs or anything like that in the future you'd be covered.
bigMikeB is offline   Reply With Quote
Old 01-29-2008, 05:54 PM   #3
I didn't think polybutelene was still approved? I think they are going to use PVC from the meter underground for economics, but I want to transition to copper for durability once above ground, with copper in the walls except for a few areas we will run PEX due to access constraints.
Old 01-29-2008, 05:58 PM   #4
Union HVAC Tech.
Poly is still the pipe of choice in NJ, not sure where you are. I don't like hard pipe underground so I would never use pvc.
Old 01-29-2008, 06:12 PM   #5
Send a message via AIM to Marlin
How long is the run going to be?
I prefer copper underground.
Marlin is offline   Reply With Quote
Old 01-29-2008, 07:10 PM   #6
I am in LA. DWP uses PVC for all their feeds nowadays. I am out of it for the choice from the meter to the unit, so I am using copper to support the hose bibs, pressure regulator and to feed the guest house. Sprinklers will be on a different line.
Then copper to enter and tie in and then pex to go where it is too tough to do the copper.
Old 01-29-2008, 07:23 PM   #7
i belive la would be under the UPC code? the code would let you run 3/4" depending on the pressure and distance. double check with the inspector to be safe
ranman469 is offline   Reply With Quote
How to Reduce pipe size wrv369 Plumbing 5 05-22-2012 01:33 AM
4 inch drain pipe econdave Building & Construction 7 06-04-2009 12:57 PM
reducing pipe size for sink drain bluebee1314 Plumbing 5 12-02-2007 01:53 PM
Steam Heat Pipe Size? helpless handyman HVAC 5 11-25-2007 09:10 PM
Pipe size for hose bibb BigJimmy Plumbing 1 03-12-2007 02:53 PM
