Septic Vent - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-21-2012, 05:46 PM   #1
septic vent
Im having major problems with my plumbing or septic really dont dont know what it is?
I was wondering if septic tanks need breathers or vents cause all the odors are coming
Back through the kitchen sink and it stinks bad I have mobile home and insstalled
The septic my self!
rc1985 is offline   Reply With Quote
Old 08-21-2012, 08:47 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 564
normal septic tank does not need a vent. Check the auto air vent under the sink. It may have failed in the open position.
Old 08-21-2012, 08:55 PM   #3
Rewards Points: 13,458
It will look like one of these if there is one under the sink.
http://www.bing.com/images/search?q=...vent&FORM=IGRE
Other things that can cause it is a dry trap under the sink and a block vent.
Has the sink been making a gurgling noise latly.
Old 08-21-2012, 10:46 PM   #4
No it dont make no noise I need to check the p trap then?
Old 08-21-2012, 10:48 PM   #5
I dont think it has One of those vents
Old 08-21-2012, 11:00 PM   #6
Take a straw and suck some water up into it, put your finger over the tip of it and lift it out of the glass. What happened? Now remove your finger. The water goes down right?
That's how a sewer vent works in the drains in the house. The vent goes from the drain system up through the roof in most cases. It lets sewer gas out and when water goes down the drain it lets air in so it will drain.
If the vents plugged up and you try to drain the sink or a toilet flushes it has to get air some how, so it can suck the water out of the trap under the sink trying to drain.
Water in a trap acts like a check valve holding back the sewer gas.
Old 08-23-2012, 12:46 PM   #7
So what do you suggest I do ?
Vent sizing pment Plumbing 5 04-19-2011 07:21 AM
Air admittance vent with septic system. Roy Rowlett Plumbing 4 06-14-2010 09:53 AM
septic vent issue utilitylocator Plumbing 1 03-15-2010 01:14 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
