-   -   septic vent (http://www.diychatroom.com/f7/septic-vent-154409/)
rc1985 08-21-2012 05:46 PM
septic vent
Im having major problems with my plumbing or septic really dont dont know what it is?
I was wondering if septic tanks need breathers or vents cause all the odors are coming
Back through the kitchen sink and it stinks bad I have mobile home and insstalled
The septic my self!
TheEplumber 08-21-2012 08:47 PM
199 Attachment(s)
normal septic tank does not need a vent. Check the auto air vent under the sink. It may have failed in the open position.
joecaption 08-21-2012 08:55 PM
It will look like one of these if there is one under the sink.
http://www.bing.com/images/search?q=...vent&FORM=IGRE
Other things that can cause it is a dry trap under the sink and a block vent.
Has the sink been making a gurgling noise latly.
rc1985 08-21-2012 10:46 PM
No it dont make no noise I need to check the p trap then?
rc1985 08-21-2012 10:48 PM
I dont think it has One of those vents
joecaption 08-21-2012 11:00 PM
Take a straw and suck some water up into it, put your finger over the tip of it and lift it out of the glass. What happened? Now remove your finger. The water goes down right?
That's how a sewer vent works in the drains in the house. The vent goes from the drain system up through the roof in most cases. It lets sewer gas out and when water goes down the drain it lets air in so it will drain.
If the vents plugged up and you try to drain the sink or a toilet flushes it has to get air some how, so it can suck the water out of the trap under the sink trying to drain.
Water in a trap acts like a check valve holding back the sewer gas.
rc1985 08-23-2012 12:46 PM
So what do you suggest I do ?
