Septic Tank Settled - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-18-2013, 07:48 PM   #1
septic tank settled
Just bought the house and had the system updated in Oct. Spring has sprung and one lid is 7" lower than the other now. Seemed to happen a couple days time. Both lids seem to be flat across the top but the furthest lid from the house is much lower. Should I be worried? I have pics only phone but idk how to upload
snilzilla is offline   Reply With Quote
Old 04-18-2013, 07:52 PM   #2
Rewards Points: 13,978
I'd like to see how you would knew this. The tank should have been completly under ground.
Pretty important that tank sits level for it to work right and to keep the lines connected.
Old 04-18-2013, 08:30 PM   #3
I can see the lids that are above ground. I managed to upload them to my albums on my profile but can't transfer over to here because my phone is smarter than me. Feel free to take a look at them and transfer to this post. Thanks for your help!
Old 04-19-2013, 06:59 AM   #4
Rewards Points: 3,130
Not here. New septic systems are required to use a plastic tank, and the access cover must remain visible. Being in the Chesapeake Bay watershed means we have a number of requirements nobody elsewhere has ever heard of. Gotta love the EPA.
Old 04-19-2013, 07:30 AM   #5
So is this normal or should I request the re-do it?
Old 04-19-2013, 07:57 AM   #6
joed's Avatar
Rewards Points: 13,308
Does not look good to me. I would call the installer back.
Old 04-19-2013, 08:16 AM   #7
Will do. I'd rather do it now and out of there pocket rather than mine. Thanks for your help
Old 04-19-2013, 09:36 AM   #8
Civil Engineer
Rewards Points: 4,854
Best to check the lids with a level. You indicate the lids are "flat" but one is 7 inches lower than the other. By flat, do you mean level? I presume the lids are steel, so they will always be flat, but it is hard to understand how they could both be level yet one is 7 inches lower than the other, unless they were built that way. A careful explanation of exactly what you mean, and how you determined the 7 inch differential, would help to understand your issues.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
snilzilla (04-19-2013)
Old 04-19-2013, 09:45 AM   #9
Concrete & Masonry
Rewards Points: 620
The only way that I know of for this scenario to happen is if the top of the tank would have collapsed. Not totally unheard of, but it is rare. Not sure what the tanks are made of, but the most common set-up "HERE" is pre-cast concrete tanks with concrete risers to get the lid to grade. The risers generally come in 6" increments in height, so a 6-7" difference in height could have been there the whole time............
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
Old 04-19-2013, 09:50 AM   #10
Ill put a level on them when I get home but yes, by flat I meant level. That's what I don't understand. My basic understanding of the system it should be one tank so I don't understand how one lid has settled. Is there a system that uses 2 tanks?
Old 04-19-2013, 09:56 AM   #11
Concrete & Masonry
Rewards Points: 620
Every system "HERE" uses at least two separate tanks, and some use three.......
Old 04-19-2013, 11:55 AM   #12
Rewards Points: 37
Not as many MD. At least in WV you can direct discharge. I was talking to some installers from WV last yr. at a certification class they said they only put plastic tanks in where they can't get a concrete tank in.
MD had some new regs. go into effect 1-1-13 & I had to have (6) new certifications to keep working on the new required BAT systems.
TOOL82 is offline   Reply With Quote
Old 04-19-2013, 12:32 PM   #13
joed's Avatar
There is obviously a lot settling by looking at those pictures. If those lids were level when installed then something has shifted. If it is two separate tanks then I would expect the pipe connecting them has been pulled apart.
The Following User Says Thank You to joed For This Useful Post:
Old 04-19-2013, 12:35 PM   #14
Thanks everybody for your feedback! Waiting for a call back from the septic guy
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 05:55 AM
septic - could you fill a 1500 gallon tank in 10 months? denemante Plumbing 20 12-10-2012 04:16 PM
Septic tank missing T and badly angled main line? denemante Plumbing 3 11-22-2011 09:29 AM
septic tank problems. littles Plumbing 1 02-24-2010 09:30 PM
Septic holding Tank Settled phillyd2 Plumbing 7 10-17-2007 11:33 AM
