Septic Tank Outlet Pipe Broke In Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-04-2009, 07:10 AM   #1
Septic tank outlet pipe broke in tank
While attemting to snap off the clay 90 degree outlet pipe in the second chamber of my septic tank it broke at the wall of the tank.
I was going to install a sludge filter.
Is there a fitting or something that I can slip into the 4 inch clay pipe then install the filter to that?
ClydeOspark is offline   Reply With Quote
Old 04-04-2009, 07:41 AM   #2
Rewards Points: 1,512
I would want to say that anything that fits not too loosely and then caulked into place will do.
If the new arrangement does not have a baffle or 90 degree bend so the water surface never drops close to the open end, then your filter must block grease.
AllanJ is online now   Reply With Quote
Old 04-04-2009, 07:51 AM   #3
The filter is designed and made for this application.
Septic Tank Vent Pipe ddave23 Plumbing 29 07-18-2011 12:21 AM
what is this septic pipe for and can I "fix" it? (see pictures) utilitylocator Plumbing 4 03-25-2009 11:49 AM
Install manholes (access) hole in concrete septic tank cover rkpatt General DIY Discussions 2 02-23-2009 06:37 PM
stuck iron pipe on oil tank vent wrybosome Plumbing 3 01-13-2009 09:43 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 09:54 PM
