-   -   Septic tank outlet pipe broke in tank (http://www.diychatroom.com/f7/septic-tank-outlet-pipe-broke-tank-41774/)
ClydeOspark 04-04-2009 07:10 AM
While attemting to snap off the clay 90 degree outlet pipe in the second chamber of my septic tank it broke at the wall of the tank.
I was going to install a sludge filter.
Is there a fitting or something that I can slip into the 4 inch clay pipe then install the filter to that?
AllanJ 04-04-2009 07:41 AM
I would want to say that anything that fits not too loosely and then caulked into place will do.
If the new arrangement does not have a baffle or 90 degree bend so the water surface never drops close to the open end, then your filter must block grease.
ClydeOspark 04-04-2009 07:51 AM
The filter is designed and made for this application.
