Septic Tank Hole - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-23-2009, 02:48 PM   #1
septic tank hole
a fire truck ran over my septic tank and now there is a hole in the top. Can i still use the shower and the toilet untill it gets repaired? Guess this is a better problem to have rather then having my house burn down from a brush fire!!
kieselba3 is offline   Reply With Quote
Old 06-23-2009, 03:17 PM   #2
Obviously you will want to replace the cap as soon as possible to prevent a small child, animals, trash, dirt and rain water from washing in but I see no danger in continuing to use the tank until you replace the cap. Worse case scenario is you could potential overflow the tank with water that wouldnt drain into the leach field as quickly as in a closed system.
faucetman886 is offline   Reply With Quote
Old 06-23-2009, 09:28 PM   #3
35 YEAR MASTER PLUMBER
MACPLUMB's Avatar
Exclamation
Septic tank hole !
YOU WILL WANT TO HAVE THE TANK PUMPED AND ANY TRASH OR DEBRIS
FROM THE BROKEN TOP REMOVE FROM THE TANK,
IF YOU TELL THE PUMP CO. OVER THE PHONE THE PROBLEM SO THEY CAN BE PREPARED TO ENTER IF NEEDED TO PICK STUFF INSIDE THEY CAN ALSO
REPAIR THE TOP LID OF THE TANK OR REFER YOU TO SOME ONE ELSE
WHO CAN THEN MAKE THE NEEDED REPAIRS
JERRYMAC@UTAHWEB.COM
35 YR. MASTER PLUMBER WITH PH.D IN WATER HEATERLOGY, MASTERS DEGREE IN DRAINLOGY,
PLUMB ANY PIPE, SNAKE ANY DRAIN, MAKE COLD WATER BOIL ON A FREEZING DAY
MACPLUMB is offline   Reply With Quote
Old 06-23-2009, 09:48 PM   #4
Dr. Macplumb you forgot to mention that it's a good idea to keep open flames away from the methane leak.
hayewe farm is offline   Reply With Quote
Old 06-24-2009, 08:50 AM   #5
You can continue as normal.
The gas from a septic is a mixture of minor gases and methane and carbon dioxide it is not at all likely to catch fire.
The thing to take into account is, an open septic will be effected by rain and surface water, when this enters above the floating crust it makes it smell - not very nice.
Do cover it to stop people and animals falling in.............. and the rain!
Perryone is offline   Reply With Quote
Old 06-24-2009, 10:49 AM   #6
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 826
I hate to say this, but you should call the township health official and let them know what happened. In my state that's who has say-so on septic systems. Anything to do with the tank or leach field has to go through them. If the tank was breached in any way, they're going to want to know about it and probably want to bless its condition and any temporary covers and whatnot.
Aggie67 is offline   Reply With Quote
Old 06-24-2009, 11:16 AM   #7
There is also the question as to who is responsible for the damage, the driver or his employer, who's insurer will pay for the cost of repair or replacement?
How big is the opening on top of a septic tank? tomseeley Plumbing 7 06-11-2009 06:04 PM
Septic tank outlet pipe broke in tank ClydeOspark Plumbing 2 04-04-2009 07:51 AM
Install manholes (access) hole in concrete septic tank cover rkpatt General DIY Discussions 2 02-23-2009 06:37 PM
Septic holding Tank Settled phillyd2 Plumbing 7 10-17-2007 11:33 AM
Magnolia tree + septic tank question/problem Jemo General DIY Discussions 5 01-18-2007 09:08 AM
