Septic Tank Baffle - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-19-2009, 04:07 PM   #1
septic tank baffle
I have a concrete tank, how do i seal the baffle where goes thru my tank?There is about 1/4 gap around where it goes in.
sedwick is offline   Reply With Quote
Old 08-20-2009, 06:36 AM   #2
Rewards Points: 1,542
Please post a picture to help us visualize this situation.
For a concrete tank you can use mortar to seal arouind the inlet and outlet pipes so sewage does not leak out into the ground in the vicinity of the tank. But the clean out hatches are left sitting in place unsealed so it doesn't take tremendous effort to unstick them to lift them off.
In normal operation the septic tank remains about 80% full and the water level fluctuates upwards from time to time. Baffles are sometimes used instead of T shaped inlet and outlet pipes. The baffles need to be arranged so that the surface of the water in the vicinity of an outlet pipe pointing horizontally does not have floating grease and scum.
Old 08-20-2009, 01:32 PM   #3
I'm thinking i must have a "T" pipe. It's white plastic and looks like a T, kinda. I've read about putting grout around it, but i was wondering if there was anything else i could do to seal it up. It would be hard to get that on it while it was wet with sewer. Could i just fill the hole back up with dirt and let that seal it off?
How big is the opening on top of a septic tank? tomseeley Plumbing 7 06-11-2009 06:04 PM
Septic tank outlet pipe broke in tank ClydeOspark Plumbing 2 04-04-2009 07:51 AM
Install manholes (access) hole in concrete septic tank cover rkpatt General DIY Discussions 2 02-23-2009 06:37 PM
Septic holding Tank Settled phillyd2 Plumbing 7 10-17-2007 11:33 AM
Magnolia tree + septic tank question/problem Jemo General DIY Discussions 5 01-18-2007 09:08 AM
