Septic Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-11-2011, 05:28 PM   #1
septic tank
how full shuold a septic tank be
ccampbell is offline   Reply With Quote
Old 12-11-2011, 11:23 PM   #2
Mad Scientist
removed
Last edited by McSteve; 12-12-2011 at 07:17 PM. Reason: Post I replied to was removed
McSteve is offline   Reply With Quote
Old 12-12-2011, 07:14 PM   #3
Rewards Points: 1,500
The normal resting level for a septic tank is around 85% full which typically means the liquid is about 9 inches below the "ceiling" of the tank. Specifically the level corresponding tot he lower edge of the outlet pipe.
It works on a one gallon in (from the house), one gallon out (to the leach field) basis.
Septic tank missing T and badly angled main line? denemante Plumbing 3 11-22-2011 09:29 AM
Septic Tank not flowing into leach lines or drain field michaelschier Plumbing 19 09-01-2010 07:58 AM
septic tank problems. littles Plumbing 1 02-24-2010 09:30 PM
Adding a roof over deck/patio, close to septic tank ncpaladin Building & Construction 0 02-21-2010 12:15 PM
Foul smell from abandon septic tank in house tsduncster Plumbing 12 12-19-2009 08:55 AM
