#16 | |
Septic Systems - How much can they handle?Quote:
#17 | |
the Musigician
![]() NOW is it more of a joke? The ONLY things we put down the drains here are water, poop, pee and TP!.. period. Never had a problem. DM
[SIGPIC][/SIGPIC]Click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. to see some of my original magic tricks and trick boxes! |
| The Following User Says Thank You to DangerMouse For This Useful Post: | del schisler (01-04-2012) |
#18 |
So NO garbage disposal but even when you wash dishes, there is always some food that ends up going down the drain. It's next to impossible to completely clear a plate 100% of its food content.
How much does it cost to pump a septic tank? When you mentioned "failure", what does that mean? That the leach field stops working? If you can't wash your toilet with bleach then how do you get it cleaned and disinfected? Is it good to use that added septic bacteria to help dissolve the food/waste? The more I read about it, septic systems can be a real problem. Last edited by JackOfAllTrades; 01-04-2012 at 03:11 PM. |
#19 |
Military Mom of 4
I pump mine every 2 years (though what's suggested is every year - obviously I don't do that)
I clean my house with usual cleaners that get flushed (like bleach, vinegar, 409, barkeeper's friend). Extreme toxins like muriatic acid and some things like latex paint (etc) I don't put down the drain - all these things are diluted outside with hose-water in the yard . . . so I've never had that enter the system. This isn't because I have a septic system - this is jus tbecause I prefer to keep my DIY filth outside of the house when I scrub my tools, etc. Disposals: regardless of how fine the pieces are - many food items are not biodegradable and thus will float on the surface of the tank's water and the baffles may or may not prevent them from clogging the leach line. "Failure" can mean lots of things: leach-line is what lets the water leave the tank and absorb into the ground. . . they can fail if they're clogged and back up the system because water isn't leaving hte tank. They can fail if they collapse or are installed incorrectly and water doesn't drain out. "Failure" can also occur if the tank collapses (rare - but happens usually if people drive over top of it - something like that) Septic-lines are just always an issue sewer or septic doesn't effect that - they can collapse, back up - etc etc etc - I still prefer my septic-tank because it saves me hundreds each year. For sewer service in the city we paid about $50.00 on each water bill - overa year that's $600.00. A pumping of my tank is about $200.00 - even if I did it every year it still doesn't cost me as much. I've had serious issues with city-sewer, too - such as main pipe breaks and backups. The frustrating thing with that for me was that I couldn't just get up and fix it and be done wit hit - I had to wait for them to do what was necessary.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
| The Following User Says Thank You to Snav For This Useful Post: | DangerMouse (01-04-2012) |
#20 |
Pumping out a septic tank is a routine maintenance item. How often it needs to be done starts out as trial and error; the pumping company should be able to estimate when the next pump out should be done.
Septic system failure means that the leach field no longer absorbs liquid fast enough for the number of persons for which the system was designed. You may be able to get by temporarily with a time delay between showers or washing machine cycles. The tank rests at about 85% full. Normal operation has one gallon of liquid out to the leach field for every one gallon of sewage from the house The remaining empty space in the tank and the space within the pipes in the leach field allow a short term faster incoming flow from the house over short periods of time when the leach field can't absorb it that fast.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded. |
#21 |
As mentioned; "failure" means a lot.
I'm fairly new to septic systems so that term scared me. To me it meant "that's it, you're screwed and get ready to shell out $$". As it turns out, that may not be the case. Things like seasonal water table changes, heavy rain, roots, etc can make a bad thing seem worse. Bottom line is that a "failure" could (I stress could) be mediated by timers, effluent pumps, adjusting your distribution manifold. I'm assuming there are other things like terralifting that could help too. I don't want to sound like a company rep, but there are a LOT of easy to read documents at orenco.com that explain these things much better than I can. Last edited by Scottphys; 01-04-2012 at 07:14 PM. |
| The Following User Says Thank You to Scottphys For This Useful Post: | Snav (01-04-2012) |
#22 |
i been my house for 22 yrs and have a 1200 gal tank and have never had it pumped out. I don't use anything down the drain to help the tank. I guess i mite be lucky It is only me. I recycle budwiser maybe that is the secret??
| The Following 2 Users Say Thank You to del schisler For This Useful Post: | DangerMouse (01-04-2012), Snav (01-04-2012) |
#23 |
the Musigician
8 years here, 1,000 gallon, never pumped.
DM
#24 |
use to the only time you needed to pump your septic tank was when it filled with too much sludge, that used to take up to 30 years for that to happen.
#25 | |
From what I am gathering, it is better to OVERBUILD the system than to underbuild it. A bigger tank, a larger leach field, etc. I would probably go with a 2,000+ gallon tank and a larger leach field. I read that one can install a valve which switches the leach field lines so that the other lines can "rest" every 3-6 months. If pumping costs $200, that is not that much money. Right now I am on a city line and I pay for water & sewer usage around $100 a month. If I move to the septic area, I would have well water, which is "free" except for the electricity to pump the well. So spending $200 a year to pump still beats out paying $1,200 a year for city sewer & water. For sure I would install the anti-drain back valve. Don't want raw sewage coming back into the home. Cheap insurance. Even city sewer hook-ups require that valve. |
#26 |
Military Mom of 4
Hmm - now well water I would avoid (personally) - septic I can handle, well water I cannot so we're septic and city water . . . well "country town water"
not city.Good point about the back-up valve. . . I've considered it and I just might do that.
#27 |
call me E
Please explain how this will help on a septic system. When the tank will no longer drain, it will push the valve shut. So in the mean time you continue to flush the toilets and run dishwashers, laundry etc. Wheres that water going to drain? Against a closed valve and right back into your house. Best to be proactive and service the tank on a regular basis.
#28 | |
Even now where I live the "city water" is really just a well dug by the city. You pay for it though, $100 a month for city sewer & water. |
#29 | |
Of course like you said, prevention and tank maintenance is the best answer. The valve is mainly used in city sewer hookups but has been used in septic systems also. It's basically a one way valve. |
#30 | |
| Display Modes | |
| septic tank uphill pump systems | keith6671 | Electrical | 4 | 01-03-2012 07:04 PM |
| Septic problem or vent problem? | wilsonstark | Plumbing | 9 | 01-17-2011 07:35 PM |
| what is and how do public septic systems work? | Cliffy2k | Off Topic | 2 | 08-20-2010 12:10 PM |
| Screen/Storm Door Handle Height | Steven Z. | General Discussion | 2 | 11-22-2009 05:38 PM |
